Thread: Aluminum Fitment
    Des Moines, IA
    Aluminum Fitment
    New to the world of pre-cut aluminum panels. Question...how exact do things need to be? For example front lower panel is wider on both anglular sides by maybe 1/8th of an inch in the middle. If I need to cut to size, what is best way to do so? Grind it down after marking?
    Encinitas, CA
    good tin snips work well on the thinner chassis panels (not so much if you need to trim the firewall, though!)
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Air nibbler
    Leesburg, VA
    cut off wheel
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    The trapezoid-ish piece? If it's too wide on both sides, it goes further back.
    FWIW, my aluminum has fit pretty well thus far.
    818C | Kit delivery: 3/19/16 | Status: Powertrain installed
    Daily: 2014 CTS-V - Fat and slow
    Banned
    Aug 2011
    cut off wheel
    X2.
    Encinitas, CA
    Quote Originally Posted by Loring View Post
    FYI... I had to trim the panels around the front suspension; that seems to be a common one with issues.
    My cockpit panels all fit well, but I did completely hack up the center tunnel Al to fit my different shifter and e-brake.
