Thread: TGV Plugs
    Senior Member Solidworks-Mike's Avatar
    Las Vegas, Nevada
    TGV Plugs
    Is it ok to cut off the TGV motor and sensor plugs from the engine harness if I've removed the actual TGV stuff?
    I'll deal with the codes later down the road.
    818-S 2.5L Turbo Chassis Number: 404
    Kit Order Date: February 19, 2016 Kit Completion Date: March 19, 2016 Kit Ship Date: March 26, 2016 Build Start Date: April 22, 2016
    Build Thread: Click Here
    I did. No issues.
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Same here. You will want to be sure you cover each wire end in shrink wrap so they don't short out on anything and cause issues.
    I plan on doing a TGV delete. The wires that go to the TGV position sensor, I am going to hook to a AIT between my Awic and throttle body. The other one I will hook to an oil temperature sensor. That way I will have that information in my data log.
    Agee with insulating the wires not plugged in. A 5 volt wire bouncing against you engine block will really screw with your ECU. It would be an PITA to find the problem. I would not cut off the connector. I would seal it with shrink tubing and/or electrical tape.
    Las Vegas, Nevada
    So many acronyms in that post!!!
    TGV
    AIT
    AWIC
    ECU
    PITA
    SIHTGOSTFTFOWTM
    Jul 2012
    Encinitas, CA
    Quote Originally Posted by Solidworks-Mike View Post
    Like a design review at work: TLAs... TLAs everywhere!
