Page 3 of 3 FirstFirst 123
Results 81 to 113 of 113
Thread: Bob's build
    Member TigerBill's Avatar
    Jan 2013
    Kingsport, TN
    Holy cow, that's a lot of fan for that small a space. Puts some more 2x4's up to support the plastic and switch to a couple of "disposable" window fans from Walmart. Then consider pushing the air in through heat pump filters instead of sucking it in (you may already be set up like that, I can't tell.. Better for dust control. Not how I did mine, but how I would the next time. :-)
    Bill
    '33HR #522, LS3, TKO 500, Boyd's Tank, QA1 Shocks, Double Roll Bars
    I thought about that and I just cant see blowing a fan right on my work...even though it might keep dust out better. The space is about 16x13x8...and based on the CFM rating of the fan on max it exchanges all the air like 5x a min but there is no breeze or anything. I have a 4x8 intake filter using tacky 20x20 paint booth filters. Maybe I will just try to turn it down a little and make sure it is sealed better. I do have 2x2's and 2x4's supporting everything for the most part..it is pretty rigid though.
    I think the big thing is I didn't wet the floor....we will see what round 2 brings tomorrow...
    Jan 2013
    Kingsport, TN
    Good luck. Glad to see a fellow brave soul doing their own paint. I just got some disposable painters tarps from Lowes for the floor. here's my space after I got done - under the covered deck with two brick walls already there.
    Bill
    I wish I could have done something like that a little more sturdy but I am in the Navy and transferring soon..and the house is going to be shown soon..so had to be as temporary as possible..and easy to throw away when I am done since bringing building materials with me is difficult.
    Got the dust a little more under control by spraying the floor with water and lowering the flow rate of my fan BUT now I have some solvent pop issues so I will have to reclear the top and hood. Oh well..it is a learning process
    With me hard at work..lol
    Jul 2014
    Great progress!! I'm picking up all kinds of useful tips here. Especially your sub box, I've been scratching my head on how to install many extras on my list of extras.
    Thanks for your continued service!!!! Coming from a retired Army CPT.
  7. #87
    Thanks man...I appreciate it. I am a Submarine/Nuclear LT...hopefully retired after this next tour
    Yeah..there is actually a ton of room under the gas tank if you get creative.
    Oh...sneak peak on the body...
  8. #88
    Ol Skool
    upstate NY
    Looks good in that southern sun!!
  9. #89
    Thanks...I am actually bringing it back up northeast in a month when I transfer to CT...so I am scrambling to get it done
  10. #90
    Apr 2015
    Looks great. Love the blue
  11. #91
    Finally done with the paint and the paint booth is torn down. Been kinda slow and a learning process but it wasn't bad at all really. I think it came out pretty damn good for my first paint job..in my garage. I started in on cutting and buffing some of the panels and they are coming out fantastic actually...very easy to work with. I am using trizact 1500, 3000,(have 5000 but havent used it yet) on a da..and the Meguiars 1 step compound/polish and they are so easy to use..highly recommend.
    Sorry for the crappy pix. After these I will quit boring everyone with pix until it is together lol.
    Front of the dash after cut and buff. This was very textured before...
    This took me like 5 minutes and only to the first stage of buffing
  12. #92
    Your build is looking great. I am curious about the efi system you are using. Is it an OBD2 system?
  13. #93
    No..it is the quick fuel QFI system. It is a pretty solid setup I think
  14. #94
    Body is on..still have a lot of work to do and have to put on the doors and chin. Sorry for the crappy pix..it was almost dark when I was done. I will get more pix when the doors are on and glass installed.
  15. #95
    Ol Skool
    upstate NY
    Sweet!! That blue is awesome!
  16. #96
    Jun 2012
    CrossRoads, Pa.
    Nice Job Bob!
    Looks good from here.
    Nevin, AKA H. R. Lucky
  17. #97
    Senior Member MPTech's Avatar
    St. Louis, MO
    That blue looks fantastic on there! Great job.
    Please post more pictures, really enjoying your build thread and great seeing it in the home stretch!
    And thanks for your service.
  18. #98
    Thanks for the props
    Well it is back on the road. I got the glass installed and put everything back together. I still need to do the interior work and a bunch of aligning and tweaking to do. Still need to get the EFI running right but it is getting there.
  19. #99
    Wow looks great Bob. Are you running 17's and 18's? What did you end up doing with the grill? Powdercoat?
  20. #100
    Yep..boss eagle 18 and 17's. I haven't done anything with the grill yet. I am probably going to pull it off and paint the outside and polish the bars on it after I move to CT. I have enough to get done in the mean time. I still have a bunch of cutting and buffing to do and a few chips already to address.
  21. #101
    Car looks awesome! Great Job!
  22. #102
    Senior Member esff32's Avatar
    La Verne, Ca
    Beautiful Bob, nice looking car. Mine is the same state as it was a year ago. Hopefully going to make some progress soon. Can't wait to see it completed.
  23. #103
    Just figured I would post a little update. I am more or less wrapped up with the interior..and it is for sale now....
  24. #104
    La Verne, Ca
    Looks great Bob...sure you want to sell it?
  25. #105
    Eh..yes and no. On one hand I would love to keep it but for the next 3 years I am not going to have a lot of time being back on a submarine..on the other hand I would still like to have another project..who knows. If I get a good offer I will let it go..otherwise I still have a bad *** car in my garage
  26. #106
    Apr 2015
    Bob,
    I have really enjoyed watching your build progress. What a beautiful car!
    One question please. You never mentioned the application of anything like Lizard Skin to control heat and noise. Did you use Lizard skin?
    If not, can you comment on heat and noise issues. I did see that you used Dynomat. I am at the point now and must make a decision soon.
  28. #108
    I actually used several things. On the bottom I used a DEI thermal barrier right over the mufflers. I also applied a paint containing ceramic on both sides of the aluminum. Then I applied Lizard skin on the inside..in addition to Cool-it by thermo tec on the inside..no heat problems whatsoever.
  29. #109
    Apr 2015
    Bob,
    Thanks for your prompt reply. The DEI thermal barrier right over the mufflers sounds like a great idea. Thanks again,
    Car is sold..going to the new owner in a couple weeks
  31. #111
    La Verne, Ca
    Congrats Bob, bitter sweet I'm sure.
  32. #112
    Jan 2015
    St Catharines Ontario Canada
    Looks and sounds great Bob. First of all thank you for your service second you did a great job!
  33. #113
    So I ended up returning the guys deposit because he wasn't going to be able to register it (Mass changed their laws to be a PITA to register an already built car)...so it is back up for sale. I have been out to sea..but I am back now if anyone is interested
