When we say to our customers "if there is anything you need, please ask," we mean it.
iWire Subaru Wiring Services
Over 100 Custom 818 Wiring Harnesses Built
http://www.iwireservices.com/factory...18-wiring-kits
[email protected]
ECU boxes fully stocked!
[email protected]
Nice!
Any update on the headlight harness retro for updated front ends?
Yes. We have gotten it sorted out for the modular harness so we now what needs to be done. There are extra front harnesses here and we are looking for the headlight side of the plugs so we can get to as close to plug and play as possible for you. Would you be willing to chop the headlight side of the headlight harness off and send it to us if we can't find what we need? That way we can build onto that end and you can plug it into the pre-existing bulkhead harness?
[email protected]
I'd be happy to send whatever you needed.
[email protected]
Most recent first time fire up from Mike Q #063
https://goo.gl/photos/xsQ4Y4EyjgujYPqA7
[email protected]
Nice! Did you hear how long to install the harness?
[email protected]
Weight is a direct reflection of how many options are chosen. This one going to be a bit hefty. haha
The boxes are moved off the table to accommodate is AC system. They will end up on the battery side of the firewall instead of inside the cabin.
[email protected]
[email protected]
[email protected]
Brian, interesting idea, though looking at my iWire harness (also with 3 fuse blocks) swapping it to the battery side of the front firewall looks like it will be very tricky to access, especially once windshield and frame is in place, no? Is there no enough room under dash for both the fuses and A/C-heater gear? I guess I am going to find out as I have been planning to add A/C and heat at some point! I hope I can fit it! :O
-Ben
[email protected]
I don't think it will be to difficult to access in front. I am hoping I don't need to access it much anyways.
By nature of your build. Which is the same as mine. Only difference for you is you have DBW and I don't. It's going to be a bit tuff when you get the cowl and body in place. It's doable but not easy like a normal car. But at the same time this car is so low and tight it's not terrible in my opinion. It's easier because you don't have to contort your body to get into the passenger side to get to fuses. This is the 3rd outside reversed harness we have done. I had the 1st 2. I also added some tips to help you install yours easier than me. You will have to cut a second hole in the firewall and loop the front harness section back out where the battery hole and shifter cables go.
Nice, I will have to check out your guide and tips. I am not too worried about another hole in front firewall. I will probably weld the current one shut if needed. I am thinking about doing a floating center console. With mechies shifter linkage, I have more cable slack. I might tilt shifter back slightly and run cables up the back of the floating center console.
Also, technically, the front aluminum pieces aren't even a true firewall, I just need to seal it for water.
Getting excited!!
So one of the only issues I have run into is that the service plugs (2 green plugs) need to be made longer as I have to take my dash off every time I want to flash the ECU
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
I would just run them to a switch so that you can just flip it from the dash at anytime. We've done this for a few cars.
Oh and just finished our most complex build to date. It was a fun one!
https://www.facebook.com/iWireWiring...09780789052181
[email protected]
Tony, that is interesting as I don't have a problem with service plugs being short. Wonder if it could be the way the harness is routed? I made a mount for the OBD plug mounted on the right side of console and the service plugs tied off right next to it.
His was the first one we built after the original prototype so the plugs may be tucked behind a bit, but it's just a matter of extending them to where he'd like them. I can send you a pre-built jumper if you'd like Tony.
Yep, you can definitely do that.
[email protected]
Tony Nadalin
[email protected]
[email protected]
Just a little tweak of the fusechart, but we like the upgrade.
[email protected]
http://www.iwireservices.com/product...7-dd36cc749d0f
Show your iWire love and grab up a shirt! If you are an iWire customer shoot me a message for discount coupon.
[email protected]
iWire Mounting Kits Available for purchase on our store. Even if you don't have an iWire harness, this is a must have to secure it to the car.
http://www.iwireservices.com/product...8-01506ac306ca
[email protected]
These awesome acrylic adhesive mounted aluminum tabs on my tunnel holding down iWire harness. Only the first 2 of many I will be putting in place! They work very nice and look great in my opinion. I may or may not add the protective/grippy rubber under the cable tie (it is included in the kit).
[email protected]
http://www.iwireservices.com/iwire-swap-map
With over 700 builds to date we thought it would be cool to create a customer map. The Blue tags are for the 818s, so check it out and see if you had an 818 buddy that you didn't know you had!
[email protected]
In for Millions (I'd settle for enough for a CNC and shop to put it in though).
I was on your site today (looking for a logo for a project, ) and saw the map. Pretty cool!
Zero Decibel Motorsports
Check out my new website!
