![Boig Motorsports](https://thefactoryfiveforum.com/attachment.php?attachmentid=181712&d=1679150850)
0
0
Any issues with this xxr wheel/tire size setup?
I am looking at the following setup:
17x7 5x100 +35mm xxr 530 (front)
215/40/17 tire
17x8.25 5x100 +35mm xxr 530 (rear)
255/40/17 tire
I am running rear wagon width links. I heard I need to decrease my offset because of this.
I am looking not to scrub anywhere and ensure a good tire fit. Not looking for 235 up front.
Would this setup work?
Originally Posted by
Ekim7878
215/40/17 tire
255/40/17 tire
I chose the same size XXR wheel and tire sizes that GRM did:
Front:
215/40R17 tires on 17x7.0-inch wheels, +35mm offset
Rear:
255/35R18 tires on 18x8.75-inch wheels, +35mm offset
The front fitment is what's recommended by FFR. My donor was an 06 WRX wagon, and I fit the 18x8.75 +35 with 255/35's with adequate clearance, so you should be fine.
I ended up with xxr 530's in gold in the following sizes.
Front:
Rear:
255/40R18 tires on 18x8.75-inch wheels, +35mm offset
For tires I went with the Bridgestone re71r.
Here is a picture with them on: https://www.instagram.com/p/BKQfiydjnGR/
I had to use hub centric rings and tuner lugs. Everything fit nicely.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
