Getting a good deal at a local parts store as my brother is letting me use his body shop account to order parts
I'm going to order a Base kit and plans are for a ls1 or coyote.
Brake list:
-1995 mustang front spindles
-1995 mustang 5 lug front hub
-1995 mustang 5 lug rear axle "not sure if this will work out not with my fox body 8.8 21spline"
-1995 mustang rear caliper brackets "axle to caliper bracket' --- will this work or do I need to order the 5 lug fox body brake disc conversion bracket
-new reman 1995 mustang cobra front calipers with brackets/loaded
-new reman 1995 mustang cobra rear calipers with brackets/loaded
-1995 mustang cobra rotors
-off the shelf brake pads
Will my brake setup work? or do you prefer a different year mustang to base my brake part numbers off.
random parts that I will need LIST:
-1993 mustang gas tank " Is this the correct year to order and do I need to order the pick up tube with fuel pump also?
-1993 mustang power steering rack "should I use a 1993 or 1995 rack? and whats the difference between sport and non sport?" I'm planning to make my own custom lines
-1993 mustang radiator
-off the shelf hayden heavy duty electic radiator fan/control unit.
anything I should add to this?
If you guys can chime in on my part list of what to add that I might be missing for major parts to keep me going with my build or what to change for something else. Your advice is highly appreciated as i'm pretty noob here but I have the chance tomorrow to make one decent size order from any mustangs any year/model all at one time.
