Results 1 to 11 of 11
Thread: Starter not Cranking
    Sep 2015
    Hello all,
    I am ready to start my 818C but the starter will not do anything. I can hear the starter relay click when I turn the key but I get nothing from the starter. No clicking, no slow turning, nothing. I have checked my connections and have a ground to the starter from the motor mount location as described in the manual.
    I am using an I-Wire harness and have emailed them, but would love to get this thing started today. Any suggestions? I have power to the brake lights, and I can hear the fuel pump start when I turn the key.
    thoughts?
    thanks and Happy Father's Day!!
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    Any voltage to the starter with the switch at on
    BN's Avatar
    Also is the eng. grounded
    Sep 2015
    Engine is grounded to the chassis where the motor mounts are. per the manual. I will verify the power..
    thanks
    This may sound dumb, but is the battery both new and fully charged?
    Sep 2015
    not a dumb question at all. It is new and I verified voltage on it. I am going to try bypassing the clutch switch and see if that does it
    Sep 2015
    problem solved. the starter relay was loose in the fuse box. simple fix. thanks for the suggestions
    iWire's Avatar
    Lake Forest, CA
    Glad it was an easy fix. Sorry about the delay in getting back to you, I was moving over the weekend.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    Sep 2015
    Brian, thanks for the response on a weekend. I appreciate the great customer service. your harness literally saved me weeks of work and the install was easy. I would highly recommend IWire for those that do not want to deal with the harness on their own.
    After I got the starter issue fixed, I was able to run the car for the first time. here is a link to the first run if you are interested. the Harness is by IWire and exhaust from AJW. Thanks to both for awesome customer service.
    https://goo.gl/photos/xsQ4Y4EyjgujYPqA7
    Leesburg, VA
    Congrats on the first start! That's brave running the engine with no gas cap on - one spark and KABLAMO!
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by mquam99 View Post
    You're quite welcome!
    [email protected]
