I wanted to share a neat feature I noticed on my Elan NP01. These cars are built by the same guys that build the Deltawing and Panoz cars- True professionals. After building cars for the last 16+ years, I thought I knew every trick in the book....haha, well, not really. Grab these two items to make wire running painless and trick/professional looking. Best of all it's SIMPLE! You can use the adhesive for other things also- Bonds metal to metal, plastic to metal etc! The tabs can be hidden and glued anywhere. Super strong, but can be removed with a good whack of a screwdriver and hammer. You use the bond on one part, then a quick spray of the activator on the other part. Then attach and it sticks. Way easier than mixing epoxy. You can secure wires, or anything else without having visible zipties here and there.
https://www.amazon.com/THOMAS-TC-105...eywords=tc-105
https://www.amazon.com/Loctite-Yello...85+fl.+oz.+Kit
