Just for reference, with auto-x, we do have multiple starts in one day, with a pretty short drive between.
Our hope, based on other autox'ers is that this battery will easily make it through the day, and that we can just disconnect it for the weeks between. If not, we have a pretty serious jump box & will swap out for a battery that can. Race cars not starting is no fun, when you need to be pulling up to the line.
"bug" fired up very quickly on the lead acid, so hopefully the same will be true with this battery, so it shortens the cranking time & WH consumed, so there are more starts per charge. We will just limit the AWIC pump time without the car running.
