Thread: Fuel Pump Really Close To Header?????
    Running A mechanical fuel pump on a very mild 302,(250-300 HP) I have only about 1/4 in clearance to the headers I'm worried about heat Transfer, Its just a Holly style pump I got off of eBay Pump works really good but Seems a bit big in diameter. Any thoughts or recommendations ? I want to stay mechanical. Keep it as simple as possible.
    Colorado Springs
    I agree. You need to install some kind of heat shield. Or a smaller fuel pump. Don't be afraid to dimple the header to gain another 1/4" of clearance
    .boB "Iron Man"
    www.RacingTheExocet.com
    Raleigh, NC
    I'm confused. I have a SBF engine with mechanical pump and screw-on oil filter just behind it. My DS front header clears the filter by a good four inches and the fuel pump by at least six inches. You must have custom headers that are very different from my standard ones.
    Can you post a pic?
    I'll get a pict in the am.
    Sounds like Vladik has the stock headers not the 4 in to 4's so with the J-pipe it gets real close which is why they include the filter relocate. When we build with stock headers I use an Elec fuel pump.
    Senior Member ram_g's Avatar
    Houston, TX
    I have a 302 with stock (reversed) headers and J-pipes, and yes the fuel pump is very close to the header on the driver side. Also the oil filter (I have a 90 deg. adapter, not the remote setup) and the oil pressure sensor are also real close.
    To make it work I conceived and fabb'd up a heat shield from aluminum - see pictures below. I played with a piece of cardboard to get the 3D shape before cutting it out of aluminum. The shield is double reinforced at the top, insulated front and back with aluminum-backed fiberglas insulation, screwed on to the front of the DS heads using a couple of aluminum standoffs, and kept from flopping around with a brace at the bottom screwed in to the 4" tube.
    All in all it works very well and in 2 years of driving my car in the Houston heat I have had zero problems from this issue.
    FFR Mk3.1 #6720. Carb'd 302. Fun.
