edwardb
I'm not positive where you're at in your build, but you don't have the chassis done and body mounted yet, right? Unless you're using a painter that has a chassis to fit your body to (there are a couple) you're jumping the gun a bit. The body needs to be fit to your chassis, panels mounted and gapped while on the chassis, etc. before it can be painted.
Mr Edward!!
Nice to hear from you
yes, yes, as always you are absolutely right, to get it painted the body needs to be bolted into the chassis already, however, what I was looking for is a shop to start working in the body itself and have it as ready as possible then to get the chassis installed so they can do the final touch-ups and then get it painted, you know... to save some time
that is the reason to look for some one close enough so i can tow my self the body first and then the frame.
Have a great day!!
