Start working on fire wall.
Front suspension partially installed. Lower arms on back order :wacko:
Looking good. You may want to fit the clutch cable to the pedal assembly now. Check to see if you have to clearance the pedal box area some. I had to on my last 3 builds with the new style quadrant unit. Just push the pedal all the way down with the cable in place to check for clearance.
Looks like you are off to a great start Roman!
Thank you guys!
wallace18, I think you talking about this clearance?
Maybe some can share picture of this part of cable setup, not much info in the book..
Might want to lube that cable up with some teflon or similar. I know mine squeaked for awhile before I did once the heat gets to it and drys it up a bit. Also, if you're going to go kart it for an extended period of time, a firewall brace for the upper left corner isn't a bad idea if you can fab one up. The body eventually holds the firewall in place but there is still some flex even with the body on. The xxr's are going to look sweet! Take special note to where they tell you mount the brake resevoirs. Not sure if they've changed the manual but the first revisions had people mounting the res way too high. You've only got a 1/4" or so above the firewall itself before it hits the body.
Thanks for all tips Erik.
Floor panels marked, but not drilled yet. I cut side panels as everyone recommended, definitely much easier to work now!
This is my two weeks progress. Yesterday received package from FFR with missing front suspension parts, monday powdercoat day.
Will try to put her on wheels next week..
Midwest 33 Build
Looking good Roman!
Thanks!
Fabulous build, keep it coming
347 stroker is here. I am very excited now!
McLeod clutch and all other components.
Flywheel and clutch in place, T5 World Class on the way.
Few weeks later..
Exhaust is next..
I use Heatshield Armor, 12" x 48" x 1/4" Thick
Heat wrap on pipes as well. You can also see E brakes installed.
I used Willwood Universal Parking Brake Kit Pt# 330-9371
Thermo-Tec for Heat and Sound Suppressor.
Power Steering controller location.
I was able to start engine this weekend. What a great feeling!
Looks like you're making great progress Roman! Are you going to take it down to HB to compete for the "Best In Progress" award?
Keith
Congrats! looking good, keep up the posts and good work.
progmgr1
Keith
I'll try to make it!
wallace18
Thanks!
Hey Roman, those wheels/tires look great - I've decided not to go the R888 route, but I'm curious what size wheel/tire you have there?
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
RoadRacer
Wheels XXR530
19X10.75 +15 rear
18X9.75 +20 front
Tires
275/35/18 front
305/30/19 rear
Here is first Go-Kart!
No gas pedal installed yet
Great go kart video.. I love the drive-by-wire!
I had one once where the fuel went into a gas can and had a friend runnin alongside with it
build thread
Do you like it?
Post Thanks / Like - 0 Thanks, 3 Likes
looks killer! I'm a big fan of black on black on black
build thread
Glad to see you back on the forum, Roman.
Just curious: what shop are you using to do the bodywork?
Keith
