Thanks Thanks:  20
Likes Likes:  104
Page 9 of 25 FirstFirst ... 789101119 ... LastLast
Results 321 to 360 of 967
Thread: Adam's Canadian 13B Rotary 818-SR Build
  1. #321
    Edmonton, Alberta
    They are pretty much Plug and Play via the CAN connections. Hook up 2 wires and everything the ECU sees the dash sees.
    After some reading I think the MXS Strada will be the way to go. I don't need it yet, lots to do, and for initial startup a laptop will suffice. When the time comes Wayne, I'll contact you about a price.
    So I finally put this thing on the ground, and "shut the front door" this thing is low!!! Does everyone just get blown away by that the first time? It's been two days and I still can't believe it when I go out in the garage.
    So I rolled it out in the driveway to start my rough alignment. My garage has a drain in the middle so it's very uneven, everything sits on 3 jack stands. My driveway is perfectly level side to side a an even 3.8 degree slope. Great for adjusting toe, no good for caster, but in my head it should work for camber if the wheel is strait and the chassis and ground are level side to side. However I'm showing -3 degrees front camber before I start adjusting, which from what I've been reading should be impossible. It does however visibly look quite cambered.
    Also, does anyone else have a taller rear tire then the front? My fronts measure at 25" and my rears at 26", so should I rake the chassis a 1/2"? Since they're taller than most, I figured I should set ride a little higher so the suspension rests where it should. And adjusting ride height is a huge PITA with the wheels on, but it would take forever to take them on and off a dozen times since there's no way of knowing how much to spin them for the desired drop. My current ride height is 5.375" front and 5.875" rear. To get the rear that low the spring collar had to be lowered about 1/2" from Wayne's recommended preload. I'm guessing a combination of tall tire and lighter engine(with turbo off too).
    As always, thoughts and comments are welcome.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  2. #322
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Congrats on the milestone and yes, literally everyone including myself went "woah" the first time off the jack stands.
    I am running staggered too but I dont think it matters for rude height. I will set the frame with about 1/4" rake.
    When doing alignment, I like to put each tire on a large cement paver. Between that and the tire i put a sandwich of two 1/8" plexiglass (from lowes or HD) with grease in between. Then i get a laser level, the kind that self levels and projects a vertical and horizontal line. I use the horizontal line to find perfect level and then add additional 1/8" plexiglass squares under any tire that needs it untill all 4 are level. Doesnt have to be on the beam, you can measure up or down to the beam from the pavers.
    I was able to get tons of camber too, but prob what you will find is you have little to no caster. Adding caster robs your camber so you have to cut down rear control arm nut tube and the studs to shorten. I need to do that myself, just as soon as I finish the exhaust update. With 3 degrees of caster, I couldnt get more than about -0.75 camber.
    Can't wait to see how this rotary drives. Should be awesome on the track.
  3. #323
    Edmonton, Alberta
    Ah, that explains the camber thanks. Maybe I should just take my time and build the car up to level in the garage like you did and get it bang on. In your alignment thread you mentioned that there was a pic of making the rear lateral links parallel, but I couldn't find it.
    818 SRX - #91
    Arrived 01/02/2014
  4. #324
    Hindsight's Avatar
    Atlanta
    Showing camber setup:
    https://imgur.com/UrbX4Hz
    Caster setup:
    https://imgur.com/cUutzj6
    Getting all tires level:
    https://imgur.com/Y9tY0oH
    What you are looking for:
    First check inside, and zero it out here:
    http://i.imgur.com/Cx7sam2.jpg
    Next check outside and ensure it is still at zero. If so, you are parallel else adjust and recheck.
    https://imgur.com/FL5SiCM
    One more thing: your laser level device should stay in one spot. You can locate it where it will hit all the blocks or cone close. Use some angle iron as shown in the pic to hang the ruler a few inches off each block if you have to in order to hit the beam (though I didnt need to hang it iff on this side but I did on the other side of the car). If you use the angle on all four blocks whether you need it ir not, it keeps the measurements consistent. Man this is hard to explain, esp typing on a phone lol.
  5. #325
    Jul 2012
    Encinitas, CA
    Yup; even though I've had mine rolling before, it's been on jack-stands for a year and I had gotten used to working on it and climbing in it that high. It's not done yet, but a couple weeks ago, I had to drop it down to the ground and rolled it out to the driveway when we put an epoxy floor in the garage, and had the same reaction... this thing's a friggen go-cart!
    I stuck to the recommended tire OD which is 1" larger in the rear: 24" in front and 25" in back (215/40-17 and 255/35-18 rubber) You may have some rubbing issues, particularly that larger. As far as ride height, to keep the suspension geometry the same and provide some additional clearance, setting the ride height 0.5" higher to account for the 1" larger diameter sounds reasonable to me.
  6. #326
    Edmonton, Alberta
    Caster setup:
    I appreciate you taking the time to post those pics and explain everything. Believe it or not, I think I understand, lol.
    I imagine that to adjust those arms parallel you adjust the upper trailing arm?
    818 SRX - #91
    Arrived 01/02/2014
  7. #327
    Edmonton, Alberta
    Quote Originally Posted by wleehendrick View Post
    Thanks for confirming it sounds right, sometimes things sound good in my head until I say it out loud and see someone's reaction, haha. I have rubbing issues, and that was expected. I have to start cutting to fit, but first I thought an alignment was a good idea so I don't have to clearance it twice.
    It really bugged me that FFR limited us so much on tire size. IMO this car needs its wheelbase extended 4", front and rear wheels an inch forward and rearward respectively and 2" in the cockpit. Since I was not consulted on its design I'm forced to adapt what I feel it should have had to what I was given.
    818 SRX - #91
    Arrived 01/02/2014
  8. #328
    Hindsight's Avatar
    Atlanta
    Yes you adjust it with the upper link that attaches to the firewall. Its a VERY sensitive adjustment. A little goes a long way.
  9. #329
    QC, Canada
    Cool! So much space in that engine bay!!!!!
    Yeah I too was impressed by the ****ing low ride. Check out my last update (will do after writing this!) on my thread about that.
    5" of the ground up front? I can't get more than 4.3 or something, maybe you got taller tires than I have. We are limited in tire sizes if we want to keep it without modifications (which you won't).
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  10. #330
    Edmonton, Alberta
    Thank you sir! You've been most helpful.
    Yep, lots of space! I should have my turbo manifold studs here next week, I'm excited to fill up one side of the engine bay. Soon I'll need to figure my intercooler and oil cooler locations. My friend came by yesterday and has me really doubting if my efforts to run a a2a intercooler will be worth it. The plan as of now is to either place the intercooler at the driver side scoop like Dan with air exiting into the engine bay, or form the scoop to feed a 5" hose going back to the intercooler by the rear bumper sealed off to the bumper and hose.
    818 SRX - #91
    Arrived 01/02/2014
  11. #331
    Edmonton, Alberta
    Been a few weeks, I was away for work. However there was a big box from summit, small bag from Full-race, and a msg from my local shop saying my AEM stuff was in! Gotta love that! I've been picking at the car the past week, not much to post about. Finally finished porting my manifold and tapped for my Full-race studs. Just waiting on my dual Egt gauge kit to arrive before mounting the turbo. Installed 500# springs in the rear, finished welding up my rear LCA's and powder coated them. I now think I have everything needed for wiring, except for the ecu, but I won't need that for awhile. Hope to start laying out the AEM and painless harnesses tomorrow and make a plan of attack. My focus will be on the engine, everything else can wait.
    My alignment took a lot longer than expected, big thanks to Hindsight for all the tips, they helped a lot. Obviously I'll need to adjust again once at full weight, but it needed to be close before I start hacking up fiberglass. I was extremely surprised at how much caster I was able to get, so much so that I had to re-read the instructions to make sure I was doing it right. Here's a pic of my setup and finished numbers...
    As you can see by my progress going down I lost camber and gained caster going down the list. However even at my final settings the rear upper adjustment wasn't maxed out on either side. There's still camber to be had and keep +6 caster.
    Front
    350# springs
    +6* caster
    -1.5* camber
    3/16 total toe in
    5" ride height (25" tires)
    Rear
    500# springs
    -1* camber
    1/4" total toe in
    5.125" ride height (26" tires)
    818 SRX - #91
    Arrived 01/02/2014
  12. #332
    Hindsight's Avatar
    Atlanta
    Wow, I am really surprised you were able to hit those numbers. I wonder why you were able to get there and I was only able to get like -0.6 camber with 3 caster? Are you running the steel or aluminum control arms? I'm on the aluminum. I wonder if they are any different. Do you have a spacer shim at the rear of your lower control arm? My next steps are to use the eccentric bolt to get more camber without having to adjust the A-arms, and adding a whopping 1/2" spacer at the rear of the control arm. I hate doing that because I know it's going to really torque the bushing at the front of the control arm but I don't have many options.
  13. #333
    Edmonton, Alberta
    I'm using steel crontrol arms from an '07 NA. I was one of the first kits to get the non-slanted upper control arms, I don't recall them making any more changes to these. I'm also confused at the numbers I was able to get.
    818 SRX - #91
    Arrived 01/02/2014
  14. #334
    Hindsight's Avatar
    Atlanta
    Hmm, I'm kit #225 and I think I have the slanted upper control arms..... I wonder if that is why. Or if I have them on upside down?
  15. #335
    Edmonton, Alberta
    Post a pic of your upper control arm.
    818 SRX - #91
    Arrived 01/02/2014
  16. #336
    Hindsight's Avatar
    Atlanta
    Here you go. I guessthese are the non-angled ones after all....
  17. #337
    Edmonton, Alberta
    Yeah, those look like mine. I'm happy with my numbers, but feel unconfident given others experiences.
    818 SRX - #91
    Arrived 01/02/2014
  18. #338
    Edmonton, Alberta
    I mocked up my A2A intercooler tonight. I'm going to order this CX-Racing intercooler, which is ironically made for an RX7. It's going to be a tight fit, it'll sit a little higher than in the pics because of the tapered end tanks. I'll also have to relocate the gas cap further back on the quarter panel, but this will be minor compared to the fender mods. I also need to reroute my coolant hose through my lower firewall. I feel with everything sealed on the front side of the IC and one of Kurk's scoops, I should be ok for cooling. It's a rather large IC, and 4" thick.
    818 SRX - #91
    Arrived 01/02/2014
  19. #339
    QC, Canada
    Yeahyeah, that's your excuse for no working on the car?
    Front
    350# springs
    +6* caster
    -1.5* camber
    3/16 total toe in
    That's damn awesome.
    Remind me what you did to get that much caster? Just bolting the FFR parts on or you moded something, changed a part, added a part, removed a part...?
  20. #340
    Hindsight's Avatar
    Atlanta
    Looking forward to seeing how that intercooler works. I think I may move my oil cooler there.
  21. #341
    Edmonton, Alberta
    Yeah yeah yeah, excuses excuses, lol. I've done no mods to get that much caster, which is weird. The only thing I can think of is that I haven't seen anyone else use an '06-07 NA as a donor. Most donors are older, newer wrx's, or people just got the '06 aluminum arms.
    I was going to put an oil coolers on the other side to match, but I'm afraid it won't be enough. The rotary relies too much on oil cooling to risk it, so I think I'll run dual 25 rows up front like a few others have done and just use my right side vent/scoop for an intake.
    818 SRX - #91
    Arrived 01/02/2014
  22. #342
    Hindsight's Avatar
    Atlanta
    How soon do you think you will get to that? I'm very curious to see how you do it and where you mount it. Given I was hitting 240 degree oil temps on the track, causing me to have to stop racing before the session was over, I need to re-do something with my oil cooler setup. I would put one in front but was hoping to use the front vents for brake cooling ducts.
  23. #343
    Edmonton, Alberta
    A few pages back in the build threads Wayne posted a "quick build" thread which made us all feel bad about how long we're taking, lol. Anyway, there's a pic in there showing his dual front coolers. I believe chad also did on his R, and I'm not sure who else. I wouldn't worry too much about brake cooling, I don't think anyone is overheating the brakes with the 818, too light.
    818 SRX - #91
    Arrived 01/02/2014
  24. #344
    Edmonton, Alberta
    I don't have much to update, although I have been making progress, and have some questions for you fine gentleman. But first, what I've been up to.
    I'm using a painless harness for whatever my AEM harness doesn't cover. Painless does a good job of labelling their harness, however you have to keep in mind that's it's meant for a 20ft long muscle car with the engine in the front. So I started by laying out the harness and grouping the sections to suit the 818. Not gonna lie, it's initially overwhelming, but one wire at a time, lol.
    Laid things out, there's no shortage of wire length. I also finally got my EGR sensors so I was able to finish my turbo manifold, wrap it, and install the turbo. I already have everything to make my exhaust, but I'll leave that for when I'm inevitably waiting on something to be delivered.
    I spent most of my day studying pinouts, schematics, and instruction manuals. Before this car, the extent of my wiring experience was some trailer lights and an mechanical to electric fan swap. So it's been a steep learning curve. What gets 5v, or 12v, what needs a relay and what doesn't. The nice thing about both harness is what needs to be fused already is. I also played with the AEM software, and while the tuning side is still well over my head, the initial setup is simple enough. My advice is to make good notes, understand what goes where before you start adding wires or terminating.
    I spent about an hour removing what I needed from the Subaru harness, and I really feel for those who "dieted" the stock harness, what a nightmare!
    What's everyone's thoughts on heat shrink butt connectors versus a bare butt connector and seperate heat shrink? A friend was recommending the later, but it just seems easier to use the others. I can't imagine it mattering.
    And where's a good place to find Subaru schematics? My donor was a 07 NA, and I need to find the DBW pedal pinouts, I believe they call it the APP. Also need to know what wires what on the VSS.
    818 SRX - #91
    Arrived 01/02/2014
  25. #345
    I have been the chief electrical engineer on building over 200 vehicles (cars, motorcycles, and trucks) over the last 10 years. This is what I specify.
    I only use Non-Insulated Butt Connector, Brazed Barrel, 22-18 Ga. Del-city 21005 or equivalent.
    Heat Shrink Tubing, Flexible 0.187" Adhesive Lined, Corrosion Resistant, Flame Retardant, Fluid Resistant, Self Extinguishing, Water Resistant(4.8mm) 3 to 1 Black 4.00' (1.22m)
    Ideal 30-429 Multi-Crimp Tool. I've looked long for a better crimp tool. This is the best for what we are doing.
    pm me you email address. I have 06-07 NA/ wrx /sti wiring manual.
  26. #346
    Junior Member DrunkenSailor's Avatar
    Highlands Ranch, CO
    I also have a PDF of the service manual for the 06/07, including the H4SO engine if you still need it. PM me if so.
  27. #347
    Edmonton, Alberta
    Thank you both for the offer, Bob I PM'd you my email address. Also, I'll go with your suggestion on the non insulated butt connectors.
    818 SRX - #91
    Arrived 01/02/2014
  28. #348
    QC, Canada
    Adam, no one will ask you that question but I am lolll, why do you have 2 glasses of water on your table?
  29. #349
    south-central CT
    Bob,
    Thanks for the good info! 3M seems to have the only shrink tubing that meets your criteria. I wonder what you think of "Waterproof, Solder Sleeve Heat Shrink Butt Wire Cable Splice Connectors"? I bought a selection of these on Amazon and see that they are now discontinued. I like what I have seen from their ease of use and performance so far. I have had experience doing Mil-Spec wiring and soldering. I know that soldering can create stiff joints that can fail under vibration, thus (I think) the preference for crimping by the military.
    To Canadian818 (sorry, I forget your name): I wonder why you went with Painless and what you think of them. I bought a fuse block assembly from them and was struck by the unplated connectors, cheap wire and overall low quality. It seemed to be typical Chinese crap. How is your experience?
  30. #350
    Edmonton, Alberta
    You notice the oddest things Frank, I believe it was my daughters glass, haha.
    To be honest Scargo I just don't know any better. All these years of Painless commercials on the power block and local availability are probably the reason I went with them, and I've nothing to compare it to, so I can't really judge the quality.
    818 SRX - #91
    Arrived 01/02/2014
  31. #351
    south-central CT
    Fair enough, Adam.
    There are a number of types of wire suitable for automotive use. Here's some basics of what's available. Besides PVC, You can get thinner and lighter cross-linked wire insulation. Requirements for aircraft wiring are pretty stringent and some building race cars use wire meeting those specifications. After experiencing a racing heat related fire and seeing numerous engine bay fires I believe in using higher temp insulation for the engine and engine bay. I recently bought a pigtail (for a new 7 pound, 55 amp alternator) off Ebay and it was PVC junk wire and cheap plastic connector.
    PVC Automotive Wire:
    GPT - Type GPT automotive wire is intended for use whenever SAE J-1128 specifies general circuit wiring. GPT automotive primary wire features extruded insulation, and has a recommended temperature range of -40°C to 80°C.
    TWP - Type TWP automotive wire is a lead-free PVC option. It is thin-walled, lightweight, and small, so it is a good choice for cramped automotive applications. TWP automotive primary wire has a maximum temperature rating of 105°C.
    HDT - Type HDT automotive primary wire is general circuitry wire, but it is less common than the other types of automotive wire. However, it offers greater physical protection than those types because it has the thickest wall. HDT automotive primary wire meets the requirements of SAE J-1128, and can be used in cars, boats, buses and RVs.
    Cross-Linked Automotive Wire:
    GXL - Type GXL (general purpose cross-linked) XLPE automotive primary wire is the most common type. It works with most standard automotive wire connectors and may be applied in engine compartments where higher heat resistance is required according to SAE J-1128. GXL automotive wire is thin-walled, giving it a small diameter for hard-to-fit areas in trucks and trailers. Its recommended temperature range is -51°C to 125°C.
    SXL – Type SXL (XLP) (special purpose cross-linked) XLPE cross-linked automotive wire has a temperature range of -40°C to 125°C, 60V,, so it may be used in engine compartments where higher heat resistance is required according to SAE J-1128. SXL automotive primary wire has a standard wall thickness.
    TXL – Type TXL (thin wall, cross-linked Polyethylene) XLPE automotive primary wire is the extra-thin wall version of the cross-linked wire, making it the smallest and most lightweight option. It meets SAE J-1560 and SAE J1128.specifications. Like the other types of cross-linked automotive wire, TXL automotive wire has a temperature range of -40°C to 125°C (257°F).
    Tefzel wire is a brand of flame-retardant ETFE insulation is thin and light, but resistant to abrasions, cuts, fuel, oil, and most solvents. Tefzel is multi-strand tinned copper automotive and marine grade wire.
    There are also aerospace and military grades that are PTFE or PET insulated or double insulated with Polyalkene and then Polyvinylidene Fluoride. $$... Spec 55 wire seems to be the high-end race car wire of choice.
  32. #352
    Edmonton, Alberta
    First off Scargo, thanks for all the info. Secondly, you and I have very different versions of what's "basic", haha. Besides what was included with the AEM and Painless harnesses, this is what I've been using...
    I don't have anymore info on it. It's quite flexible and the insulation is thicker than what's provided in my harnesses.
    I've been busy, and fabricated a mount for my coils. It's upside down in this pic, I was starting the coil harness. I also went ahead and powder coated my upper intake manifold because it looked like crap after shaving off some unnecessary tabs. I didn't bother with the lower intake manifold as it will be one of the first parts upgraded with the fuel system after getting it on the road. Most all my engine wiring is complete, just the alternator, starter and some grounds to finish up. Obviously still lots to do before startup, but it's finally all coming together!
    818 SRX - #91
    Arrived 01/02/2014
  33. #353
    Aug 2012
    Long Island
    One is water. One is straight vodka.
    because 12 hours of wiring.
  34. #354
    QC, Canada
    Damn right!!!!
    Finally Adam we get to see some kind of engine! Looks great with the glossy black!
    You've got a weird TBody and a starter so similar to my racing Porsche one. It must be cool then.
    Hey I saw Viper parked yesterday while I was walking around, recent model. Thought of you immediately cuz... it had kick-*** wide tires!!! lolll
  35. #355
    Edmonton, Alberta
    Damn right!!!!
    Haha, I oogle at my tires all the time. I'm happy with the black, the exhaust will be wrapped black, and I plan to paint my other transmission black as well before installing it. I'm considering powder coating the intake piping, but it might be too much. I could do another color but I don't want it to be tacky. I went with blue coolant hose and I'm already second guessing if it looks tacky. Need to make some plug wires soon too, and not sure what color.
    The throttle body is an GM LS3 unit flipped upside down, starter is Subaru, but from an older model. Hopefully I'll get to start on the exhaust by this weekend!
    818 SRX - #91
    Arrived 01/02/2014
  36. #356
    Aug 2012
    Long Island
    I used the MSD plug wires on my RX7 was impressed with the quality. I'm guessing you need something custom because of your coils?
    http://www.streetbeatcustoms.com/MSD...-32919/771901/
  37. #357
    Edmonton, Alberta
    Yes, I'll have to make my plug wires. I believe most manufacturers make a DIY kit, and I had another friend recommend MSD as well.
    Slowly making progress this week, much of my time being spent studying schematics. The only thing left to figure out is the ignition switch pinouts and how to wire a relay for it. I'm picking up a battery today, and I need to fab a bracket for it to mount next to the engine.
    818 SRX - #91
    Arrived 01/02/2014
  38. #358
    QC, Canada
    What are you using as coilpack? Or distributor pack. Or maybe coil on plug but certainly not OEM from that engine year (what year again?).
  39. #359
    Edmonton, Alberta
    I'm using 4 AEM smart coils, the OEM setup uses 3 coils and an ignitor. Not sure what year my engine is from, but I suspect '96-'02 because of the 16bit ecu it came with.
    818 SRX - #91
    Arrived 01/02/2014
  40. #360
    QC, Canada
    Oh, so that's one coil per plug meaning it's not a wasted spark it's almost like coil on plug, you can control spark ignition and duration. As long as your ECU will allow you to change parms. Mine can if I had these. I start to wonder if I should. loll 19amps max each but since pretty much only one at a time is working then the current draw may well be under 25amps max. That's more than my coilpack which is fused at 10a but those look more powerful.
