Results 1 to 5 of 5
Thread: Driverside footbox Header Clearance
    Senior Member RickP's Avatar
    Boyertown, PA
    I've been reviewing some threads trying to address a concern I have with the driver side footbox to header clearance. I'm really close to making contact with the corner of the footbox. What are my options at this point and should I even worry about it until I fit the body? The gap is small enough that I cannot get my index finger in between the two. I have tons of room on the passenger side.
    wallace18's Avatar
    Trenton, Florida
    That is the normal gap IMO. As long as you insulate the foot box you will be fine.
    Boyertown, PA
    thank you sir, I like "normal"
    I would call that clearance OK, but I have been on the unfortunate side of a header making contact with a steering shaft while on track (not in a FFR car).
    If you are really worried about it you can always "massage" the header tube with a hammer or in a vise (if possible) to give you another 1/4" of clearance. won't affect performance in the slightest.
    Boyertown, PA
    Quote Originally Posted by ProJoe View Post
    I've seen others who have modded the foot box. I'd rather detent the header as you suggest.
