Results 1 to 4 of 4
Thread: Sidepipes position sitting low
    Member AZJoker's Avatar
    www.jasonleenye.com
    I have a MKII Spec Racer. Once bolted on the J-Pipes, pipes sit lower than the body cut out. Is it possible to bend the J Pipe? Not sure how to fix this problem.
    www.jasonleenye.com
    Maricopa AZ
    Put a jack under the front of the sidepipe, loosen up the J pipe, jack the sidepipe into the position you want it and hammer the J-pipe bolts with an impact gun. It will stay.
    www.jasonleenye.com
    Quote Originally Posted by Gordon Levy View Post
    Thank you Gordon. Will try this
