Quote Originally Posted by JB91710 View Post
You and me both. or should I say, Join the club?
For my 07 EZ30 I have found out that the strongest 5 speed box should be the 05-06 legacy GT. I will have to install a limited slip down the road if I want one. If I want a 6 speed, I'm not sure which one is strongest and it has to bolt up to the EZ30. This trans has the LS so that's good. The FF end plate and gear shift hardware has to work also or it has to be available somewhere because I can't fabricate it.
Any ideas on which 6 speed is my best bet?
Jack
