20
104
Moonlight Performance
Wow, I can't even imagine having that much snow this early in the year! Well, nothing better than garage time when the weather is bad!
I apologize if you mentioned this previously and I missed it, but are you planning on building a shroud for the intercooler that will completely seal it up to the side sail so 100% of the air and pressure that comes in through the side scoop will be forced through the intercooler and if so, what material do you plan on using? I am planning on doing that for my oil cooler and have not decided on material but am thinking aluminum with bulb seal. I will use a contour gauge tool to get the curves and angles right for a perfect seal. Going to be a lot of work though....
