Hey guys, I feel like I am a little stuck here. I am trying to increase the gap between the rear of the door near the latch and the striker. I was able to line up the door so the there is about a paint stick's gap between the bottom of the side sail and the door but side of the door next to the latch is about touching so I am afraid it is going to rub against the body whenever the door opens and closes. Currently it is rubbing lightly against the bottom of the sidesail when it starts to close and then rubs all the way to the striker. Attached at the pictures of the door gap and the latching mechanism
I can't seem to pull the door away from latch area because if I do, the door will not close because the latch hits the striker and will not close. This is before I even install the door cards so once I install that, it will definitely rub.
Did anyone else have this problem? Any suggestions?
