Results 1 to 12 of 12
Thread: Phenolic Spacers
    Phenolic Spacers
    Hi Everyone,
    I will be ordering my 818c within the next 6 months but am going to be doing a quick engine refresh before hand as I already have the donor completely stripped. I Used to have an 04 WRX wagon and ran 3mm phenolic spacers and was happy with the added cooling I noticed. I am wondering if there is enough room to fit either the 3mm or 8mm phenolic spacers from Grimmspeed as I saw one build thread that had mentioned difficulty angling the engine into place. My donor is an EJ20 out of a 2005 WRX.
    Thanks in advance.
    Jan 2012
    The 8mm make it a bit tight. I have those on my build.
    Member jcpresto's Avatar
    I have the 8mm as well on my 818c
    Nepa
    i have 8mm sacer but with a 2.5i intake and it fits fine but i dont know if thats taller or shorter than a wrx intake?
    Harley818's Avatar
    Vancouver BC
    I went with the zerolift TGV deletes which are phenolic/plastic for the same reason.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    And can you use the spacers with an air to water intercooler?
    Harley818's Avatar
    Vancouver BC
    the deletes are the same size as stock TGV's. I'm not sure if the spacers would add too much height or not but If I add 8mm to my intake height it would still clear the fiberglass hood.
    Harley
    I have the 8mm spacers and AWIC. I also ground the motor twice. Above the spacer to frame, and below spacer to frame.
    Feb 2013
    Westminster, MD
    8mm GrimmSpeed phenolics on the 818R, no fitment issues.
    Edmonton, Alberta
    Quote Originally Posted by jcpresto View Post
    Wouldn't it ground through the bolts?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    I've seen issues in the past with other people. I did it just as precaution
    Bowling Green, KY
    I am using 8mm spacers with out issue, engine and trans went right in with out the header, 04 EJ205 and 5 speed.
