Yeah, the bottom rear is too much inside. What causes that?
Good luck for tomorrow man.
Gloss Black
Unfinished Aluminum
Tracked May 27/July 26, 2017
Build Completed Winter 2021
If only I knew... I had it PERFECT when I marked the holes. I think it's the rear striker/latch mount that most directly affects the rear corner.
Inspection attempt 2 failed but I'm SOOOOOOOOO close! Just need to :
-Adjust parking brake : MD requires positive engagement at around 8-10 clicks. Currently set for end of travel
-Revisit the turn signal canceller : I know it works at the end of steering travel in both directions, but I think inspector wants it to trigger earlier.
I should be done this process on Friday!
