Brian Z
David,
Here is a list of the parts in the special edition brake package:
SPECIAL EDITION FRONT 13" CALIPER/ROTOR ASSEMBLY
FRONT 13" DRIVER SIDE CALIPER W BRACKET EA 1.00 BRAKE, CALIPER, FRONT, MUSTANG, COBRA STYLE, 1.76" PISTON, DRIVER
FRONT 13" PASSENGER SIDE CALIPER W BRACKET EA 1.00 BRAKE, CALIPER, FRONT, MUSTANG, '03 MACH 1, 1.76" PISTON, PASSENGER
FRONT 13" ROTOR EA 2.00 BRAKE, ROTOR, MUSTANG, 13", 03 MACH 1
CARBOTECH FRONT BRAKE PADS EA 1.00 BRAKE, PADS, MUSTANG, FRONT, 94-04 COBRA, CERAMIC, w/ANTI SQUEEL BACK PLATE, CARBOTECH, XP 8
FRONT CALIPER BOLT EA 4.00 SCREW, FLANGED HEX HEAD CAP, GRADE 10.9, PERMA PLATE, M12-1.75 x 35mm
FRONT LOWER CONTROL ARM BOX EA 1.00 BOX, CORRUGATED, DIE CUT, WHITE, PRE-PRINTED LOGO, 20.25"x 13"x 6"
FRONT LOWER CONTROL ARM BOX INSERT EA 2.00 BOX, CORRUGATED, DIE CUT, BROWN, 20"x 13"
Best regards,
