What does the 818C use for seat belts? I'm under the impression it uses the stock donor seat belts. Is there an option for a 5 or 6 point "performance" belts?
Robert
Robert
You get tired with the Roadster already?
Ray
The seat belts will require special mounting if you want to go 5 or 6 point. Here is how I did it I am sure there are other ways. http://redfogo.com/index.php/seats-harnesses/
