Thread: Exhaust
    May 2013
    Slidell la
    Exhaust
    Is it normal for the engine to pop through the side pipes when cruising in 3rd or 4th
    Mk4 # 8834 delivered 03/20/16 2015 IRS wildwood brake upgrade, 18"x9" front 18"X11" rear halibrand wheels, 390 FE, tko600
    No. But can you supply a few details please. Also you might add intake system details to your signature line.
    May 2013
    Slidell la
    Edelbrock performer rpm intake and Holley 850 cfm carb, it's not a constant popping
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Does it sound more like an "after fire" where unburnt fuel is being lit off in the header?
    Possibly look for a miss, including checking spark plugs and wires. I had an intermittent miss in mine that got progressively worse - sounded like a dull thud through the exhaust when it would occur - and the source was plug wires that were cracking as a result of overheating from the headers.
    Later,
    Mk3.1 #7074
    Senior Member Mesa Mike's Avatar
    Mesa, AZ
    Make sure your header bolts are tight
    Senior Member Raceral's Avatar
    Stoneville NC
    Triple check to make sure your plug wires are going to the right plugs... Mine did exactly the same thing many years ago...
    Al Adkins
    Certified "Kool Aid" drinker
    If it only occurs when you let off of the throttle the most likely cause is leaking header or collector gaskets.
    I'm with Kleiner,,, I think you are sucking a bit of fresh air through the collector gasket.
