Results 1 to 4 of 4
Thread: **Sold** For Sale-Drive shaft, new
    So. Bay (So. Calif.)
    Drive Shaft is sold. Thank you.
    FFR drive shaft, new. 1330 Spicer bearings. Yoke for 31 spline TKO, flange for 8.8 Ford, with bolts. $275
    From the flat flange (pinion end) to the center of the rear U-joint is 1-5/8 inch (maybe just a sliver less, but real close), and from the center of each U-Joint is 7-1/8. So total from the flat flange to the U-Joint on the transmission yoke end is 8-3/4 inch. The 31 spline collar measures 6 inches from the tip to the forward u-joint center. Total length from tip of the trans collar to pinion flange is 14 3/4 inches.
    Nov 2015
    length?
    Length would be very helpful.
    Thks
    Quote Originally Posted by Rviscosi View Post
    Thks
    Quote Originally Posted by steveyoung View Post
    length?
    Sorry, I guess that would be helpful. See top post, I've added it there.
