I know this has been covered, but I can't seem to locate the discussion. I have the complete roadster kit and installed the side exhaust securing the exhaust to the headers (351W) and to the side exhaust mounting bracket, per page 409 in the instructions. I find that the PS side exhaust is approximately 1 1/2" higher at the rear of the exhaust than the DS side exhaust. And, as the PS exhaust is higher, the side exhaust mounting bracket is tight up against the 2" by 2" outer tube. And, I'm concerned the mounting bracket will rub on the frame and will also interfere with attaching the body.
So, before I start into modifying the mounting bracket or try to force the PS exhaust to a lower position, any ideas?
