In need of a donar wanting an automatic I dont care what year or model does not have to run going to rebuild entire powertrain anyways. Not looking to spend more thand $1000 please. Thank you for looking.
Squid,
Both my donors were forester xt automatic (04 &05)
My transmission, shifter/TCM are available if you pick them up.
It is hard to find a running turbo donor under 2K.
Finding a NA running under 1k is easy.
Here is a donor I would bid on:
https://www.copart.com/lot/18020047/...edLot=18020047
2004 2.5L turbo, automatic 76k, runs and drives. I suspect you can get for $2500.
Thank you NA is fine with me can you PM me and we can talk about your stuff you have. Thank you for the help
I am sorry stupid question not familiar with Subaru but can a Forester be used as a donor can we use control arms wiring engines trans and such or do we need Impreza only?
Squid, check this out. I found it helpful. (not mine)
https://docs.google.com/spreadsheets...J-E/edit#gid=1
Hi
Im in York PA. I have donor parts available for cheep.
Check out my post here: https://forums.nasioc.com/forums/sho...4#post44929914
My contact number is in the thread linked.
thanks
