Results 1 to 21 of 21
Thread: Requesting Your Seat Slider Mount Designs Please
    Hey Gang,
    > I'm getting ready to fab up my seat slider brackets & thought it would be a good idea to reach out to you all for obvious reasons.
    > What I'm trying to find out is what most of you have done so that I don't reinvent the wheel or the seat sliders in this case.
    > I'm using a set that I got from Bestop for Jeeps that I'm modifying to fit the width of the F.F.R. Big & Tall Leather seats.
    NOTE: I need a lot of adjustment distance for both seats because my family members range in height form 4'11" to 6'4".
    Thanks-N-Advance,
    Senior Member Duke's Avatar
    Taxachusetts
    See my build thread. Exact same scenario
    Quote Originally Posted by Duke View Post
    Will Do & Thanks!
    Duke,
    I found the pics & they really help!
    Leesburg, Va
    Unless you are looking at changing the seat angle. WHY do the passenger seat? If you are, longer bolts and spacers work well. Just trying to save you a few dollars.
    Doug
    FFR 7995
    347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
    Quote Originally Posted by Bobby Doug View Post
    Thanks for wanting to help me save a few dollars; however, I'm crazy about symmetry.
    Regarding saving a few dollars, I saved a bunch going with the 383 Chevy & ZF 6-Speed since I had those parts lying around since Hurricane Katrina. (August 2005)
    Two things:
    1. Even with the low backs it's prudent to determine their placement with the body on. While not as critical as with the high backs it is still possible to have the top corner of the seat hit the body where it curves around to the back if you get them set too far to the outside. This becomes more likely with the additional height from the sliders.
    2. No matter what brand of sliders you're using they need to be parallel to the tunnel so that the seat remains equidistant from it when moved fore and aft. If the track is set in straight ahead the front corner seat will collide with the ever widening tunnel when moved forward.
    While fitting the owner to this car he was most comfortable with the seat turned just a bit to be parallel with the steering wheel (you might not realize it now but the wheel actually angles to the center of the car---and the pedals are slightly off to the left!). I made some simple brackets to attach the seat to the adjuster and you'll probably have to get creative and do something similar.
    Here is the seat all the way back:
    And all the way forward:
    Notice how it is the same distance from the tunnel in both positions.
    I agree with Doug and don't see a need to make the passenger side adjustable but of course you do want them to match side to side. On the car in the photos the passenger seat is fixed, set at the same angle and mounted on 1" square aluminum tubing to match the driver's seat height. BTW, this is the only one I've ever built with an adjustable seat and the owner reports that it has been adjusted exactly once---when he came to pick it up
    Good luck!
    Taxachusetts
    So my kids (and passengers) can reach the foot rest I built so they are more comfortable:
    Duke & Jeff
    Thanks Gentlemen!
    Member Toy4me's Avatar
    Voorhees NJ
    I bolted the passenger seat to the floor. I have short legs so I had to make the drivers side adjustable. I did not like the adjuster handle on the outside and would have to bend the arm. I swapped sides and made the adjuster a push type instead of a pull type for the other side. This puts the handle on the inside of the seat. I used a rod with heim joints instead of a cable. Works great. To bad nobody will ever see it. I do have some pictures somewhere.
    Quote Originally Posted by Toy4me View Post
    That's why I ordered the sliders from "Bestop" instead.
    The adjustment bar is attached to both sides and pulls up.
    You just need to cut & modify it a bit so that you can reduce the width.
    They were Powder Coated too.
    Mar 2013
    Medway, MA
    Steven,
    Being 6'4" I would advise you check your seat height with the body on and windshield installed. A seat track under your seat will likely have your eyes above the top of the windshield.
    Mark Reynolds
    Raleigh NC, OIB NC
    The Jeep seat adjuster is a very nice piece but pricy. That said from a user point of view the $30 odd dollar sliders from Jeg's or Summit (Jeff's Picture) work well. Found once I had the correct position I have not changed it in 18 months, about 7500 miles. Passenger seat is bolted in.
    Kevin
    MKIV #8234
    Quote Originally Posted by Mark Reynolds View Post
    Steven,
    Mark Reynolds
    I've already checked that issue and I'm A-Okay, with what I've come up with so far, plus I have the Big & Tall Seats which sit a tad lower.
    Also, I'm 5'10" and it is my brother and likely future son in law are both 6'4".
    Thanks!
    Senior Member smithbks's Avatar
    Mar 2014
    Atlee, VA
    Steve,
    I have actually never adjusted my driver seat and wish I had just bolted it down to begin with. The slider forced me to find new bolting points instead of just into the seat pan. I had to tap one into the 4 inch tube and another in the frame just above the rear lower control arm attachment. All that for a seat I have never adjusted! I'm 5'9" and the seat is nearly all the way back so even if someone wants to adjust it I'm not sure they gain much.
    I used the FFR adjuster and I found the quality to be just OK. I would recommend another brand. However, it has two good features: 1) it is very thin so you really don't have to worry about the seat being raised up and 2) it has a front pull that is easy to get to.
    Passenger side - once I fit my wife to it and she was near the back as well I decide to just bolt it in. Now it is even with my seat too. I decided against sliders for others because she will be my primary (and most important) passenger.
    Good luck getting Bernard in there comfortably!!! I hope he fits.
    Mk4 #8340, 351w/427, 3-link, Wilwood 4 piston rear brakes, 3.27 gear, TKO600, delivered June 18th, 2014
    Quote Originally Posted by smithbks View Post
    Steve,
    Davey, Brenton & Jarrett will likely be driving this thing, but getting Bernard comfy, hummmmm ?-?-?-?-?-?-?-?-? maybe in the passenger seat since his feet don't fit in the drivers side foot box very well.
    On a roll Al_C's Avatar
    Wheaton, IL
    My 2 cents to an interesting conversation: skip the adjustment. Set the seat so it fits you and tell everybody else that you are the only one who can drive it!
    The issue is we are A Car Crazy Family and tend to hop into each other rides from time to time.
    Brother 1999 Mecham 427 T/A, Son 2000 Camaro, Wife 2012 Challenger, Daughter's Boy Friend 1955 Chevy Pick Up Truck.
    Add in the fact that my lovely better half is my designated driver means that seat needs to scoot, even if she is wearing heels.
    Gotta Get Home Safe & Sound Since Bourbon Street Is Only 1.5 Blocks Away From My Office So: . . . . . .
    Have you checked w/ your insurance company yet? My wife and I are the only ones allowed to drive my FFR.
    Yep & We Are A-Okay!
    Thanks!
    Good I just wanted to be sure. As I said my wife and I were listed as the only drivers on ours. And then they wanted another paper signed by wife and I stating that our 22 yr old daughter, away at college at the time, was specifically prohibited from driving. W/ insurance companies, one never knows.
