Results 1 to 6 of 6
Thread: Wilwood Brake Upgrade
    Nov 2016
    Petaluma, CA
    Does anyone know if any of the Wilwood brake upgrades work with pin drive, 15" wheels on the 289 FIA builds?
    Thanks. Joel
    Maricopa AZ
    I have 4 piston systems designed to work with 15" wheels
    Junior Member Clark L Creswell's Avatar
    Jan 2018
    Melbourne , Florida
    Hey Gordon;
    How's things in the Sunny Southwest ? What would a set of rear calipers (Wilwoods) for Pin Drive Live Rear run for 15 " on USRRC Mk 4 ? Hope all is well with you !
    Regards , Clark Creswell
    Maricopa AZ
    Depends on what rear end you are using. They range from $895 to $1099 for a kit.
    Nov 2016
    Petaluma, CA
    Hi Gordon, I am thinking of making the transition to Wilwoods on all four corners. I am building the 289 USRRC FIA. Rear end is the 3 link Moser narrowed for pin drive 15" wheels. I am assuming that I can just replace the calipers that came with the complete kit and should not have to do any re-routing of the hard lines? Can you send me a proposal and a quote via email? Email here is fine or at [email protected]. Thanks so much. Joel
    Maricopa AZ
    I will email a quote over. The front and rear are complete bolt on kits including any needed lines and fitting.
