Thread: whats wrong here?
    Question whats wrong here?
    I have a MK4 and with 4.6 modular engine.
    my foot box aluminum comes in contact with motor.
    yes it is the modular motor aluminum.
    Shane
    Member HB_Ryan's Avatar
    Huntington Beach,CA
    Your feet will get toasty!
    MKIV Roadster #8862
    Order Date- 4/4/16
    Delivery Date- 4/30/16
    Completion 1/15/17
    Huntington Beach,CA
    Is it already on the engine mounts?
    MKIV Roadster #8862
    Order Date- 4/4/16
    Completion 1/15/17
    How old is your kit? They made changes to the footbox within the past year or 2...
    Kit is early MK4 Summer 2010.
    I have a 3/8 spacer between mount and frame on driver side already.
    Engine is offset to passenger side 1"-1.5" with reference of crank center-line and 4" tubes.
    I would not think i need to cut and re-weld engine mounts....
    Huntington Beach,CA
    David is correct, here is a pic of mine with the newer footbox
    MKIV Roadster #8862
    Order Date- 4/4/16
    Completion 1/15/17
    2bking's Avatar
    Garland, Texas
    Unless you want to change out the sheet metal for the newer version, you are stuck with the rub. A 1/2" spacer under the DS mount may get a tiny bit of clearance. If it were me, I would opt for the newer sheet metal which will fix the engine rub and get more foot room on the inside. I think FFR sells the set for about $100. With the new metal, the engine can be leveled with the same spacer under both mounts and the side pipes will fit much better.
    King
    Just to be sure...your motor mounts aren't swapped to the wrong sides are they? On the driver's side the locating pin will fall into the slot below the stud. Passenger side will have the pin to the rear of the mount stud. The engine and trans are offset to the passenger side by design.
    Thanks for the reply's I've opted for new metal from FF.
    Shane
    Been to long need to finish this project.
