I have a quick question, I rebuilt my Lincoln Mark VIII pumpkin with 3.55 gearing and a Eaton True Track. The true track comes with a spacer that fits within the True track, I wanted to button up the pumpkin with the back cover before I install it within the frame. but if I install the spacer before installing it in the frame the space can fall out through the axle holes, Did anyone here not install the spacer or did you install the space after you got the pumpkin and axles installed?
