Thanks Thanks:  19
Likes Likes:  73
Page 2 of 21 FirstFirst 123412 ... LastLast
Results 41 to 80 of 825
Thread: Making progress on my build...
    Senior Member beeman's Avatar
    Indiana
    GTM #304 LPE 525hp LS3
    LCD Gauges's Avatar
    Toronto, Ontario
    Are you going to have room for scissor hinges?
    Indiana
    Yes, around 99% sure (edit- yes, definitely). I started mocking up a hinge this afternoon, I'll post a quick picture here to give you an idea. Basically had to figure out the axis of the hinge/pivot point. This was based on images from multiple cars with butterfly doors. I then took this as close to the inner fender, as far forward as the hinge would allow. I then created a hinge from 1.5" square from that pivot point to the front edge of the door. Now I just need to attach the pivot point shroud to the chassis below the a pillar. Looks like it should work. Grabbing Chinese food, enough for today.
    This pic was earlier in the process, didn't take any more. Initially I made a 90 degree dogleg in the plane of the pivot bolt, this wasn't right, so I removed some tack welds and fixed it. The hinge basically is angled in 2 planes.
    LCD Gauges's Avatar
    Toronto, Ontario
    Right on. If you need any more photos or tips, let me know.
    You should be miles ahead with having the door flush with the hood/fender, as opposed to inset.
    Indiana
    I've had much worse first attempts! I'd like to tweak the angle a little, slightly more horizontal arc of motion. This came out more like a vertical door than a butterfly door.
    Indiana
    Version 2.0
    Complete redesign with Toyota door hinge.
    I think it's perfect.
    Yes it clears the fender nicely!
    Not too different from its inspiration...
    Indiana
    So I've been thinking about the best way to hinge the doors with a rock-solid hinge system, and realized that I'd seen something similar to the Ford GT race car hinges somewhere before...Underneath my Honda Foreman!
    Is there much play in the bushings on these? Maybe too much play? Been thinking about this, maybe the sleeve bushings allow too much play, I'll check into that.
    Not these specifically, but something like it.
    San Diego
    I think you will find range of motion an issue on those...unless you don't tighten the through bolts down and let the inners rotate on the bolts.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Indiana
    OK, back to the electric power steering. Using an Equinox column. Lower shaft installation appears to be fairly straight forward. Looked at mating the C5 upper tilt column to the EPAS, not a great option. I'm not upset by that, because the C5 tilt system is insanely heavy and has that stupid column lock. Going to use the tilt column from the Equinox..how exotic! Then I ran into an issue finding a 6-bolt (Momo) hub adapter that works with the Equinox. Most GM steering hubs are 3/4" 36 spline. This one is 5/8" 36 spline. I could not find ANY hub adapter from Momo, NRG, etc. anywhere for a 5/8" 36 spline. That changed this morning. Found a place out of Arizona that makes all sorts of hub adapters, billet aluminum. Looks like a quality piece. They build a 5/8" 36 spline for AUSTIN HEALEY SPRITE MK1/2 1958-64 ; MG MIDGET MK1(SLIDING WINDOW CAR) 1961-64. Sweet! And about half the price of a Momo/NRG hub adapter, $48 with free priority shipping.
    Should have it in a few days. EPAS unit fits well in the footbox.
    http://www.flashpowerparts.com/en/au...let-black.html
    Senior Member dallas_'s Avatar
    Dallas, TX
    Good progress, keep posting!
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Indiana
    Waiting for packages to arrive, got bored. Saw the Sawzall laying there.
    Anyone adamantly opposed to me incorporating this fascia? Speak now or forever hold your peace...
    Indiana
    OK, figured I should have a real crash structure up front. Going with 1.5" DOM. Tube bender was feeling neglected. Funny, 'Dead Man's Curve" by Jan and Dean playing now on Pandora. When I was building my roadster, I enjoyed listening to the stuff Carroll listened to when he was out in his shop. That has carried over to my GTM build. Takes me back to a time when guys were building no-nonsense muscle cars, and the next champion could come out of anyone's garage.
    Getting started :
    Edit: notching is a necessary evil. Really messy with the cutting oil... In this pic, the wheel is in full lock to verify clearance.
    Indiana
    Here's a basic photoshop of this fascia on a GTM without modifying any of the intakes...couple colors...
    Dallas, TX
    Interesting. Might help to see what you plan for headlights.
    What is that fascia from?
    Indiana
    The fascia is from an mr2 spyder, what do you think of it?
    I actually have 5 different OEM headlights in the shop that I have gathered over the past year, each has its pros/cons. I'm leaning towards an HID projector setup from a superbike
    Since you asked politely, Dallas, here is a sneak peek:
    Bee-
    I like the new fascia. I also like your colors; no chance of not seeing you coming! One thing that I think makes a big difference with how these cars look, is complementary, or even contrasting colors. Things like painting the screens or intakes black, or a contrasting stripe make a big difference.
    I like the headlights in the above pic. I also think the new trend of the line of LED lights looks awesome on the GTM.
    Mad skills by the way! This is a very cool build, and I respect the work you are doing!
    Indiana
    Thanks Steve! Yeah I agree about the contrasting colors, the photoshops above are not predictive of my planned paint, just wanted to throw the fascia on the GTM shape.
    Slowly but surely, the complex intersections are a nightmare to get notched correctly...
    Update, got the upper crash structure tacked in collinear with GTM chassis to 1/16" and 0.1 degrees. Will fit the radiator before building lower structure. Upper edge of center of structure 19.25" off the ground.
    Dallas, TX
    I think whichever front clip you go with, you'll make it look great.
    There are things about both that I like, such as the vertical slits at the front wheels on the original clip.
    By the way, the roadster looks fantastic!
    Indiana
    Getting the radiator mocked up. I can angle it from vertical to horizontal... I'm thinking angle it as close as possible to the path of airflow exit? Still trying to decide whether to exit at hood or vented wheel wells. All airflow before and after the radiator with be completely sealed (I think this is critical for high speed aerodynamic efficiency, not to mention cooling efficiency). Any thoughts on which is better (hood vent vs send to wheel wells)?
    This is a Champion radiator for a Cherokee. My calculations suggest it will be more than adequate. I have plenty of room for a size upgrade if needed down the road.
    LCD Gauges's Avatar
    Toronto, Ontario
    I think wheel wells might offer an easier escape as the cowl seal is imperitive for keeping rain water out of the front end.
    I'm thinking GTM however and your front end is no longer equal.
    Indiana
    Do you mean keeping water out from the front fascia or from the wheel wells? Where does the GTM typically draw air for cabin HVAC? Typically OEM setups have vents at the base of the windshield to take advantage of the high pressure area there. I plan a smooth transition from hood to windshield. Climate control air will come in through one of the front fascia openings (probably) vs a hood NACA duct.
    Indiana
    Getting column mocked up for installation.
    Will retain tilt function... If there's enough room! I mean I might want it as high as it can be all the time.
    Banned
    Aug 2011
    The two pieces of tubing you have going from the frame to your front facia look dangerous. They're aimed right at the two occupants and it seems to me, IMHO, that with an impact they might enter the cabin. There's no real crush zone with heavy tubing the way you have it. You might want to redesign or maybe use a thin wall tubing and drill some holes through them like the front end tubing on the 818. Just a heads up.
    Indiana
    Thanks for the feedback, always open to comments!
    I do plan on additional DOM tubing tied into the backbone, do you think that is enough?
    Banned
    Aug 2011
    double post
    Banned
    Aug 2011
    818 frame 2.jpgIt's that the two tubes are too stout for the job, and there's no real "crush zone". That design transfers too much energy straight into the frame. You need to use something strong enough to hold up the front end but weak enough to crumble in an impact. It would probably be easiest to use thin wall square stock to build the front sub-frame.IMG_3480.jpg
    Indiana
    I understand what you are saying. I wasn't going to triangulate the front structure, so it would buckle in a collision. Maybe I should redo it.
    To me, the front tubing that FFR uses on the GTM seemed too wimpy to protect the cabin in a high speed collision. Does anyone agree, or is it more than adequate? I think it's 3/4"?
    I also felt like the supplied front structure would ramp a colliding vehicle up towards the cabin... So I tried to create a higher structure that was more robust. I live in the land of pickup trucks and whitetails!
    What does everyone think?
    Indiana
    I just looked this situation over. The DOM tube we are referring to measures 25". If a collision drove that tubing in completely, it would end up at the level of the gauge cluster. More likely, an intrusion would occur to the level of the frame between the suspensions, an intrusion of 17". This would potentially drive the DOM tube to the mid-dash level. With the additional triangulation, I guess I would be surprised if the DOM was drive in like that rather than be end up deformed.
    It wouldn't be much work to redo it in small square stock, but I don't want to go wimpy...
    Thoughts?
    Indiana
    Big gains on the EPAS this morning. The donor lower shaft (when disassembled) is a steel rod, about 0.80". I called up a machine shop this morning (Saturday!), about an hour and $20 later, had this machined to 3/4" double-d.
    If you look at the FFR lower shaft, the splines are simply attached to a double-d stub by a couple set screws.
    Now I have a nice (collapsible for safety!) lower shaft. Donor splined coupler/male double-d >female double-d shaft >male double-d /FFR splines >rack.
    Really happy with this. Thought I was going to go nuts finding couplers, also thought I was going to lose collapsiblility.
    Indiana
    Got a little sidetracked earlier, bought a cafe bike project. Don't plan to do much with it until the GTM is done!
    Going for something like this
    Got the EPAS about 80% installed, everything in, just have to finish welding. Removed the tilt function, going with a fixed mount.
    Indiana
    Tacked in more frame. Had to wait until steering installed before this beam could be placed.
    Indiana
    The EPAS is mounted in 2 locations, at the motor housing and at the stationary housing over the upper steering shaft. Neither of these locations worked easily for my build. I fashioned a bracket from square stock to mount it at the motor housing location. The upper mount was not as easy for me to figure out. The chassis tube is not perpendicular to the steering shaft, off by 10-15 degrees. I also needed to make sure that the mounts would not trap the EPAS in the frame should it need to be serviced. I rummaged through the junk hardware and found a solution. Welded it up, works perfectly.
    Ordered 4 of these, they are 4.75" long weld-on barrel hinges. I'll cut them down in similar fashion to the Ford GT door hinges.
    Indiana
    Per concerns discussed above, moved the front collision structure down to the mid aspect of the front chassis. Maintained same height at front bar ~19.25" (which I think is an excellent bumper height for a car this low!)
    LCD Gauges's Avatar
    Toronto, Ontario
    The amount of talent on this site is outstanding. This is by far the most radical build I've come across and likely ever will...unless someone decides to redesign the rollcage and body from ground up!
    Imagine a 'dream team' of FFR members building a car one day.
    Anything you can do for safety is a step in the right direction. I often wonder if I'd ever walk away from a head-on or side collision at regular speeds inside of this car. Staring at the lug nuts of a big rig
    passing by at eye-level is motivation for taking extra time to make it right!
    Dallas, TX
    Looking good beeman! Rock on bro.
    Indiana
    Wondering how my bumper height compares to what I may be running into out there...
    Bumper height laws are state specific. No minimum height, but lots of maximum allowed front bumper heights, ranging from 20-24 inches or so. Interesting.
    http://drivinglaws.aaa.com/tag/bumper-height/
    But it sounds like Federal laws mandate a minimal height of 16". This probably does not apply to a built vehicle.
    To meet federal rules, car bumpers must be 16 to 20 inches off the ground and limit the amount of damage that can be sustained in a low-speed crash. The idea is to ensure that the bumpers on colliding cars engage, absorbing most of the energy of the impact
    http://www.iihs.org/iihs/news/deskto...and-cars-alike
    Dallas, TX
    I've never heard of bumper height being an issue getting a custom car registered and titled.
    Not to say that some states might make that part of their process.
    Indiana
    Yeah I don't think that they would even check that at inspection, I was just wondering where my bumper would meet the average oncoming car.
    I measured where 19.25" met my F150, was surprised to see that it was right in the meat of the bumper, at the lower 1/3.
    Indiana
    Getting ready to create a hood. Then will merge the FFR and aftermarket front end.
    Indiana
