Results 1 to 3 of 3
Thread: Manual steering Rack Clearance?
    I installed the manual rack today on my Mark IV. I notice the rubber sleeves on the rack touch the down box tubes on the chasis. This doesn't seem right, shouldn't there be clearance?
    Jun 2015
    Parker, TX
    Yep, it's common. Here is a similar thread - there are a couple of options listed and probably more if you search a little more.
    http://thefactoryfiveforum.com/showt...rack+clearance
    Thanks! I cut the lip off one bushing for ps and ds and moved them to the other side. Problem solved.
