I need a but of advice from the experts (y'all) again. I have the steering column installed in the lower mounting holes and the U-joint extended for maximum stretch.
The column is about half and inch short of properly connecting with the steering rack. Is this a common problem? Is there something I may have overlooked?
It seems like it would be really easy to remedy this by drilling mounting holes an inch lower for the column. I just wanted to check with you guys if this is a known issue.
Thanks Nick
