This question is for all those who have built/are building and have a real good understanding of what is/is not needed BASED on your build.
I like others here plan on a lot of new/aftermarket solutions from the vendors, upgrades from old parts with great looks !.
My donor was an 04 RS, I purchased an ej207/trans for the power. After tear down, many parts are just not what I want to use ( ie the front LCAs - replacing with the 06 aluminum )
The electrical was a mess, also the RS was an 2.5NA auto car, so I am going Painless and a MegaSquirt.
Here is what I think will be unused parts in the kit while looking at the packaging list.
80318 - Steering rack mount - (going vendor)
80238 - Push Pull cable - (MR2 - set up with bell crank)
26185 - Shifter
80312 - Hood pin set - (want an actual pull hood release, like our 85 RX7 type)
80007 - Stop tail lights - (like other aftermarkets better)
BOX 5 - lines and Coolant tubes - (going vendor)
Fuel tank - (boyds or other front mount)
80279 - Fuel sending unit ? - (why did I save the unit from the Scooby if one is included)
Again, What was in the kit that you either didn't use, or replace with something better ?
I'd hate to have a box full of stuff I am not going to need,use,or upgrade.
Thank you for the input, Be safe.
"E"
