Wiring question?
I think I know the answer but want to bounce this off the forum members for their input. I am building a GTM using a 2002 Corvette donor. I bought a PSI stand alone engine harness and the kit comes with a Painless wiring harness. By adding a few relays can I eliminate all the corvette fuse panels and most of the donor wires? It seems to me this is possible. What do you all think?
That's how I did mine years ago. I think the only things I needed from the Vette wiring was plugs for the steering column, wiper motor and power window motors.
Thanks Mike. That is what I was thinking.
