Any idea if the CTS-V calipers will be able to run a 20mm rotor?
-Jason
Several people now have approached me and asked me to make some rear brackets. I'm slow to get things done now, but I'll take a look at it (along with a fun twist )
Zero Decibel Motorsports
Check out my new website!
I hope the twist includes a way to have a parking brake lol
You can either run the adapter calipers that bob posted or KNS sells a thick set of brake shoes to make the WRX parking brake work with a sti rear rotor. That still limits you to a 20mm thick rear rotor. I've been trying to find a piston parking brake that will fit a 30mm front sti rotor but haven't found anything that will support something that large.
-Jason
I'd like to see if the wilwood mechanical caliper can be mounted for parking. It can take up to a 20.5mm rotor.
Should work just fine with the sti rear rotor but not with the front like hobby racer did.
-Jason
If you want a parking/emergency brake that would work with the wider STI front rotors, you could use one like this from wilwood.
MK3.1 Roadster completed 2011
That would work would just have to run a hydraulic hand brake
-Jason
Hmmmm....it would be interesting to find a push-button hydraulic line-lock that activates only the front brakes.....
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
What year is the Legacy brake disk, and is it only 4 wheel studs?
https://static1.squarespace.com/stat...pg?format=500w
Ah! Hobby Racer! What size are they?* I have Stoptechs that are 12.9" and they fit inside my 17 inch Wedssport TC105N's .
*I've been plowing snow for five hours and feel too lazy to search the internet!
