Zero Decibel Motorsports: Bell Crank Shifter
After quite a few requests, I've placed an order for parts to build 20 bell crank shifters. Last time I ordered 45 pieces and sold out of all but 5 within a couple weeks. These 20 will be first come first served. If you'd like to get your name on the list please contact me to place a 50% deposit. Unclaimed assemblies will be added to the stock shelf. I'll try and contact those directly that I remember have specifically asked for one.
Due date for parts is ~April 10.
Details can be found here on my product page:
http://zerodecibelmotorsports.com/pr...echanism-5spd/
Craig, I'm in !
How do I do the deposit ?
Jim
No worries. I don't sell cables anyways. I actually forwarded that link to a Canadian customer who was looking to do a setup.
You do beautiful work and hopefully you can help me. I have a unique situation as I am coming from the right side of the cockpit to actuate the transmission. I have the brackets installed for the cables but I need the hardware. The only problem I see is that your shaft bracket is installed horizontally and I need it vertically. Can you install a set screw and I'll grind a flat spot on the shaft?
