Hi Guys,
So I am finding a lot of contradicting information and would really like to figure this out. I am converting an explorer motor to a carb and had ordered all my parts from Mike Forte (who is absolutely fantastic to work with!!). I have a installed the double roller timing chain and two piece fuel eccentric. I am using the shorter dowel pin, which is correct. However, I notice that the outer part of piece of the eccentric does not rotate freely around the center piece.
Is the outer piece supposed to rotate around the center one? I have already installed the timing cover and water pump. I really hope I don't need to remove everything. But I can't imagine that a two piece wouldn't work differently than the one piece.
I also noticed that when the eccentric is installed, there is a 1/32 of an inch wobble to it.
Any help is appreciated.
