Administrator
Originally Posted by
frankc5r
Was able to hammer off one of the 2 donor front cv joints but second just would not come off. Tried Art's inertia method but could not get enough velocity in short height I had.
So I used small cutoff wheel to cut cage apart and remove the balls after which it just fell apart and I had my stub to use. took less time than all the hammering I did.
Frank, I didn't know you were working on the fron CV's when we talked. I just cut through the CV's about 3/8" off the ABS wheel. Makes lighter axle stubs.
Frank,
