The foam I used for the hood outline was McMaster 8512K96. https://www.mcmaster.com/#8512k96/=16w814b. The 25 foot piece was enough for #7750 and the Anniversary build. It's 1/2-inch thick but was thick enough to fill the opening on both builds, and is in the pictures I posted.
Haven't heard of McMaster? Heresy! I couldn't build one of these without them. Their website is easy to use, fully documents the parts they have (which is amazing), and for me with a distribution center near Cleveland, I always get the parts the next day. True they don't provide the shipping cost until after you order. But I find their shipping charges very reasonable. Pays of course to combine wherever possible, but typically it's near the actual UPS amount without a bunch of markup. Highly recommended source. I choose not to add up how much of my build budget is spent there.![]()
I didn't use pop rivets to hold the rubber snubbers in place around the hood opening. They won't allow you to adjust the body to follow the hood shape. I drilled and tapped the 3/4 inch tube for machine screws at each snubber location. I waited about a week after the final body installation, to let the body settle and find its final shape on the frame, then used the machine screws to match the hood opening and hood height. Once I had the height where I wanted it, I removed and re installed the screws, one at a time, with a little blue loctite on them. They haven't moved in three years.
HTH
Norm
I agree with Jeff. This has really not been a complicated issue in the past. Re-read Edward's comments in the bottom of his post #29.
But I Love Reinventing The Wheel!
https://youtu.be/_wnHDNgnNqs
Makes life interesting to say the least, don't you think?
I received the foam strip for the hood outline yesterday from McMaster-Carr. I placed the body on the car, with the help of Jeepurz, and it looks great. Completely filled the gap.
Thanks everyone.
Road Legal August 31, 2017
