Thread: 1999 - 2004 C5 Corvette Steering Column Bezel Cover
    Senior Member The Stig's Avatar
    Charlotte, NC
    Hello all,
    I have found that I need to replace my steering column cover assembly. For some reason, mine will not close as it did previously.
    (I have ordered one from e-bay, but I am not 100% sure if it is the correct one or not.)
    If anyone has a cover assembly (upper & lower) for a C5 Corvette Steering column, without "Telescopic Column", and you don't plan to use it, I would appreciate the chance to buy it from you.
    Please send a PM, and I'll respond.
    Thank you,
    The Stig
    GTM #0081
    Good luck! Every one that I've found (used) is cracked or broken at the mounting points. We always end up just ordering new parts from GM and use the tele cover whether the column is tele or not.....just make a small block-off plate for the tele switch hole and paint over it....since you will have to paint the whole cover anyway. These are no longer produced, so once GM runs out of stock, they will no longer be available.
    Shane Vacek
    www.vraptorspeedworks.com
    Charlotte, NC
    LOL... That's what I was afraid of...
    Thanks Shane.
    The Stig
    GTM #0081
    Oct 2017
    Does anyone sell alternative (sexier) covers and turn signal/light levers? Do most people stick with the GM stuff or make their own?
    Jul 2014
    I am nowhere near using this in my build yet, but I am wondering some of the same thing. Is there a nicer off the shelf item out there to dress this up a bit? I have not explored this yet, but I'm betting some type of carbon fiber piece would look nice.
    Banned
    Aug 2011
    You'll probably have to make your own. I've made one but it won't fit the FFR dash.
    Jul 2014
    Quote Originally Posted by carbon fiber View Post
    Making my own carbon fiber details is definitely something I want to learn how to do. It will be nice to add custom touches throughout.
