Hey everyone.
Here's my plan. I want no outside door handles. I intend to have a removable hard top. Sometimes the car will have the top on with windows up. Locked up, so to speak. In the configuration, getting to the inside handles won't be possible should the battery die, or something happen and the poppers not work. I will probably be using a remote controlled set up and not a push button setup.
The delimma. Has anyone here set up a mechanical fail safe to be able to open the doors from the outside when a top is installed (and windows up) should a mechanical method be needed? Electric failsafe would be easy via hidden button but doesn't alleviate the problem of dead battery or electrical failure.
