I have been getting the car ready for the summer here, and last night when I tried to start it, the gauges turned on and I hit the starter. Everything went dead. So I assumed the battery was dead. I charged it and later around 10pm it was done. I bumped the starter and the car rolled over. But, I didn't want to start it. It was late and the car is loud. But I turned on the lights, checked the speedo gauge miles, and shut it down and removed the keys.
Next morning, it did the same thing, no power!? So I went and got a new battery, But it's still will do the same thing. You can tell the gauges have power, but the volt gauge has not moved. You can slowly see the gas needle climb, but its not much power because the speedo isnt turning on to show the mileage. I tried to start the car and you can see the gauges react to the draw, but I don't even hear a click, just silence.
I checked main fuse, and ran a voltage meter and tested a few areas, I am seeing all 13.4 in the engine bay.
Any help or suggestions?
