[QUOTE=VD2021;21910]
Yes, the lower points are per the manual. I don't think there will be any clearance or alignment issues with the brackets installed. I think that they should help align the glass better with the rear door pillar. the rest of the glass fits as it should so far. I hope that wont change with the brackets on. The only modification done to the frame was trimming the part that sits against the front of the door. This was done to allow the upper part of the frame to be as inward as possible inside the door. I have circled in this picture were the trimming was done. On the lower part of the frame you can still see the excess material outside of the weld.
