Thread: Help Find a Part
    Dec 2011
    Saratoga Springs, Utah
    Help Find a Part
    Does anyone know where I can find the green plug (what is it called)? Don't have a clue where or what it is called to look for it.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    It's a weatherpack - probably available on-line if you search on that name or a variation of the spelling.
    Later,
    Mk3.1 #7074
    Lastdime-
    As Chris said, it is one part of a complete weatherpack connection. You can find them at various places: Amazon, flea bay, some auto parts stores, various places online etc.
    The rubber pieces vary depending on the size wire you are using. Please ensure you get the same color replacement, otherwise you run the risk of water intrusion if it is too small. So, replace green with green in your case.
    I hope this helps...
    Agreed. Weatherpacks. Delcity.net has them in every size, along with all the other bits. https://www.delcity.net/store/Cavity...97663.h_797664
    I can throw some in a bag and send them to you if you want.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    NAPA carries some. I would call your local one before going there as their inventory positions are terrible. Often the system tells them they have some only to find out they don't. Otherwise, get them from Mike Everson (replicaparts.com).
    Kyle
    Dec 2011
    Thanks guys! Now I know what to look for and several places to find it.
    You know they are made to be removed from the connector plug right? It's not like it's broken..
    Dec 2011
    Not broken, just lost. I found some on Amazon and all is well. Thanks for all the comments and help.
