Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 207
Thread: FFR's own 818R
  1. #161
    Senior Member metros's Avatar
    NoVA
    Great job and great videos!
  2. #162
    Senior Member Mulry's Avatar
    Dallas
    Quote Originally Posted by Zach34 View Post
    When are those side scoops going to be available?
    This.
  3. #163
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    They're available now in fiberglass, just call Factory Five
  4. #164
    Jan 2012
    Wayne since you ran power steering in this car, what were your alignment specs? What would you run if it was at S height instead of the R height. I've got the R springs and shocks on my C right now.
  5. #165
    Dallas
    Thanks Wayne. Just ordered them. I'm guessing the ones on that car are CF? They look sharp but the interior fiberglass ones should suffice for our needs.
  6. #166
    Williamsburg VA
    Quote Originally Posted by Mulry View Post
    Hey what was the price from FFR? Did they saying anything about offering them in CF? Thanks
  7. #167
    Dallas
    Quote Originally Posted by taco20 View Post
    I ordered them online, so I didn't talk to anybody. Price was like $168 and change, shipped.
  8. #168
    Senior Member fastzrex's Avatar
    Oklahoma City
    I also ordered mine online, about $172 with shipping. Only available in fiberglass although I did not talk to anyone either.
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
  9. #169
    Denver, CO
    Same here
  10. #170
    Aug 2012
    Long Island
    Quote Originally Posted by ben1272 View Post
    That must frustrate the heck out of them! Nice driving.
    love it... at 33sec he does a power check... nope not enough. lol
  11. #171
    Williamsburg VA
    Hey what part number did you order because the ones I found on the FFR parts page are not the ones on the 818R car? I found part number #81145.
  12. #172
    Jan 2012
    I was about to ask the same question.
  13. #173
    Kirkland, WA
    I'm running the #81145 internal scoops for about a year now, only issue is that they require a 4" hose and most of the brake hose out there is 3" so you need an adaptor
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  14. #174
    Saline, Mi
    What are you using them for?? fresh engine air or brake air or ??
    Kirkland, WA
    Quote Originally Posted by frankc5r View Post
    I feed them into my intercooler through the 3" brake tubes and have the intercooler boxed so that the air is pushed through the IC
    Tony Nadalin
  16. #176
    Dallas
    Tony, where did you find the adapter?
  17. #177
    Wayne, I think you've just done more to redeem the 818 performance reputation than Factory Five could have hoped for with those lap times and video, great job! Cheers.
  18. #178
    Aug 2012
    Long Island
    http://www.discoveryparts.com/auto-r...ne-4-inch.html
  19. #179
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    Spectre makes a 4" to 3" adapter.
    https://www.amazon.com/dp/B002D30VGK...d=CHK8IEUB4VRD
    -Jason
  20. #180
    Administrator
    Enterprise Alabama
    Quote Originally Posted by Plebeian View Post
    Thanks, it's been fun and rewarding.
  21. #181
    Administrator
    Enterprise Alabama
    I went to Savannah to test out the larger radiator and air to water intercooler. I added 2 smaller heat exchangers on each side of the grill opening in addition to my standard heat exchanger. Coolant temps reached a max of 196 after 6 hard laps. The intake temps maxed out at 160 and 125 with the water/meth injection. Now that's when things didn't go so well. The header wrap had rubbed on the belly pan and some of it came off. The excess heat caused the timing cover to sag until it came in contact with the header and it ignited. It burned the timing belt, alternator belt timing covers and PS feed hose. So my solution is to use the DEI gold foil heat sheets on the timing covers, ceramic coat the header, wrap the headers with the DEI Ti wrap, put the form able sheet heat shield over the wrap.
  22. #182
    Sgt.Gator's Avatar
    Bend, Oregon
    Holy Cow! Obviously the engine wasn't running when the timing belt burned up. You're lucky you're not rebuilding a trashed engine.
    Crazy!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  23. #183
    Wayne,
    My solution was similar.
    I bought these 2 product from McMaster.
    https://www.mcmaster.com/#93315k51/=18396ic
    https://www.mcmaster.com/#3254k91/=1839aty
    I was going to wrap my headers and all exhaust with this. But I never implemented it.
    Right now I am running with the factory header shields.
  24. #184
    Oklahoma City
    Great lesson to take this area seriously. Thanks for sharing!
    ~ Mark
  25. #185
    Administrator
    Enterprise Alabama
    Header ceramic coated, DEI Ti wrap and header blanket
    gold foil applied to the timing covers
  26. Likes biknman liked this post
  27. #186
    Administrator
    Enterprise Alabama
    A few laps from last weekend
    https://youtu.be/GRZb30HRsy8
  28. #187
    Feb 2013
    Looks like you are hooked up on the Roebling Race line. Some odd turns there especially the off camber one. The acceleration up the front straight seems crazy! Are you on the same VIR tires? Is one of the goals FFR has with this to document your setup and determine if it is transferable to others who trying to make things work on the track?
    You are making it look easy!
  29. #188
    Not sure why nobody asked this question. The photo attached shows the gas filler on the passenger side. What was done? Any chance of this being a future option? If this becomes an option, what would the new fuel tank look like?
  30. #189
    Jan 2012
    Fuel cell on the passenger side is the reason I believe.
  31. #190
    San Diego Ca 92106
    I asked that same question a while back. Wayne said because the fuel tank was in the passenger area.
  32. #191
    Administrator
    Enterprise Alabama
    The fuel cell is where the passenger seat would be so the filler got moved to the right side.
  33. #192
    Jan 2012
    What are the alignment specs for this car Wayne sense it's running a power steering setup?
  34. #193
    Saline, Mi
    Man that is exiting to watch. you scare some drivers right off the track!
  35. #194
    Administrator
    Enterprise Alabama
    Quote Originally Posted by 07FIREBLADE View Post
    500 fr springs, 750 rear
    Fr
    -3° camber
    +6° caster
    0 toe
    .015 bump out per side
    Rr
    -2.8° camber
    3/16 toe in
    .015" roll steer in
    Same guy spun twice...second time it just broke loose in the rear and off track
  36. #195
    Senior Member AZPete's Avatar
    Wayne, you wrote, "The header wrap had rubbed on the belly pan and some of it came off. The excess heat caused . . . "
    Since I don't think this happens a lot on OE Subaru cars, what's different? A lot of turbo Subaru cars have header wrap, I think. Do the turbo OE cars have a belly pan?
    Obviously, you are pounding it hard, but is there any other cause for the excess heat and damage? And, how can others avoid it?
  37. #196
    Administrator
    Enterprise Alabama
    Quote Originally Posted by AZPete View Post
    No subaru cars have a belly pan sealed up and so close to the exhaust, the stock manifolds have heat shields on them, this is a Borla header and comes closer to the timing cover. How to avoid it, see post 185 above
  38. #197
    Thanks, Wayne. I've been planning a belly pan under my engine, so now I'll re-think it. I have a wrapped Perrin EL header and my street machine certainly has much less boost, stress, speeds and a less-skilled driver than your 818R. But, a heat shield will be a good project for me.
    BTW, I'm really enjoying your successes with the FFR 818R! Thanks.
  39. #198
    Senior member
    Carlsbad,Ca
    Pete , does your header hang down below the frame ?
  40. #199
    Administrator
    Enterprise Alabama
    It's how close the Borla header is to the timing cover. The Perrrin EL isn't as close and near as much of the cover
    Quote Originally Posted by Jim Haar View Post
    The Perrin does not hang below the frame
  41. #200
    818r center seat biknman's Avatar
    Charm City
    Sorry if this was already noted on the areo package but can I ask:
    1. How wide from end plate to end plate is the APR GT1000 wing? I believe they come up to 71” wide. And what AOA is used?
    2. Fronted splitter which one? I assume it’s the FFR race. For the front splitter how much lip stick (distance from bumper edge to leading edge of splitter) out are you useing? And the verse how much from the front bumper to the rear of splitter? Also assuming the least amount of ducting in the front is being used ie duct above splitter blocked off?
    3. The rear quarter panel duct or vent frame or whatever you call it are those avsilable or where these one offs?
    Thanks and keep up the good work!
    FFR 818r Instagram biknman69
    2020 Ram 2500HD, 19 Forester Touring DD, 96 GM coupe for SCCA SM
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    • Ernest Hemingway
