This is a duplicate post from my build thread.
Michael and I listened to some of the suggestion on here and decided to go with the liquid/liquid oil cooler and the remote oil filter.
This first picture is the oil filter mount to the post behind the driver.
The mounting plate has 4 ports. I used them for oil in, oil out, oil pressure sensor and oil temperature sensor.
The 2 sensors are wired into my ECU for logging and Dash board display.
At the bottom of the above picture you can see the liguid/liquid heat exchanger. I also added a sensor to measure the coolant temperature out of the radiator. The cold side of the radiator is cooling the oil before it goes back into the engine. Here is a picture of the heat exchanger form the bottom side of the engine.
I used a canton block to get the oil out of the block. Here is another picture form the underside of the engine.
