King,
Thanks ... I will pm you by the morning. If I understand what you all are proposing is that I would keep all the FFR hardware and just add the adapter to connect to the ********** overriders.
Since I have the Kleiner mod on the rear ... I am trying to get my head (a bit more muddled than normal) how you would tighten the 7/16-14 at the threaded standoff inside the trunk. I guess I would hold the threaded still with two nuts locked together and then turn the standoff to tighten it up against the aluminum
I will head out to the garage and take a photo and edit this post with it.
Carl
