Results 1 to 10 of 10
Thread: Rear End Vent
    Rear End Vent
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member Shep's Avatar
    Hanson, MA
    Unless you're using a 9" rear, I'd be suspicious of the "fits most other models" statement. If you're using an 8.8" rear, you can get replacement vents from several sources. They won't be polished though!
    Shep
    9087RD picked up 4/22/17 - finished 5/1/20.
    6362RD picked up 10/27/07 - Sold to John Lipka on 3/31/11
    4469 picked up 6/28/03 - finished 4/4/05. Supercharged 5.0 Claret Red Metallic. Sold to Cobra Cory in 2/07.
    Papa,
    I used the following Spectre Breather hose clamped to a NPT Barbed brass hose fitting that comes out of the top of my left axel tube:
    https://www.spectreperformance.com/s...aspx?prod=3995
    It's stainless steel mesh and the hose barb goes well up into the breather; however, I don't have pics of it to show you.
    Anyone know the typical size/thread of the fitting in the axle tubes on an 8.8? To clarify, I have a Moser 8.8 that doesn't have a fitting for the breather. Or should I just order and screw in one of these: http://www.americanmuscle.com/ford-8...bolt-8614.html
    --Nathan
    The Moser axle comes with a 1/4 NPT vent hole and a brass hose fitting. I bought the 4R3Z4022AA vent from American Muscle, but it has a 7/16-20 (-4AN) thread.
    Yes, the Moser vent hole is different from the standard 8.8. Remember, Moser uses bigger axle tubes.
    Bought a 916144 adapter from Earls / Summit and everything is good.
    Quote Originally Posted by Boydster View Post
    Thanks Boyd! I'd seen your post at one time or another and couldn't find it. I ordered the same Earl's fitting in black and will use the polished vent. I didn't want to run a piece of tubing for the vent and this solution will work and look good. I suppose if I were going to track the car, the better solution would be something like Steve suggested, but for street use, I think I'll be fine.
    Legal: 1/30/2020
    Quote Originally Posted by silver_pilate View Post
    --Nathan
    It took some convincing myself to accept that my 1/2" wide opening on my Moser 8.8 is actually 1/4" NPT, but that is the case as the male 1/4" NPT o.d. is 0.504" -- totally intuitive.
    Legal: 1/30/2020
    Thanks, guys. I ended up ordering one of these. I'll see if it works out.
    https://m.summitracing.com/parts/SUM-E730300
    --Nathan
    Senior Member Gromit's Avatar
    Mass, North of Boston
    It is when you remember that NPT is a "pipe" designation and pipe is measured by the I.D. Nothing against the plumbers out there
    Chris aka Gromit
    Factories have done it this way for many years. The TKO trannys have the same style vent mounted. I dont see an issue with it. Glad I could help.
