![Boig Motorsports](https://thefactoryfiveforum.com/attachment.php?attachmentid=181712&d=1679150850)
0
0
818 Subaru donor parts
Hi 818 folks, I have parted a couple of WRX wagons recently and have a collection of miscellaneous parts that should be useful for an 818 build. Most of this stuff could be shipped without trouble, PM or reply if interested! Located in Glastonbury, CT, near Hartford.
• MY05 5 speed transmission - 135k miles.
• MY05 Rear brakes and E-brake handle/cables
• MY05 upper steering column assembly and steering wheel (no immobilizer required)
• MY05 Pedal box and throttle pedal
• MY05 Master cylinder and brake booster, and clutch master cylinder
• MY05 Exhaust manifolds
• MY02 WRX cloth front seats (heated with wiring and switches)
• front seat belts
• gauge pod
• Radiator and fan
• Door hinges, hood hinges
• Rear view mirror
• Rear seat belts
• Radiator hoses, brackets and such
• engine and trans mounts
• Random other parts
Reason: Location
Does "random other parts" happen to include timing gears or timing covers?
Originally Posted by
turbomacncheese
Sorry, the engine is in working order so not breaking it up. Those covers aren't cheap nor strong.
turbomacncheese
I have a few of those timing cover pieces and gears laying around, depends on which ones you need.
Do you still have the MT5 transmission?
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
